Raspberry + Kali + Allo Piano 1.1 dead due to shortcut
Nothing… Find bellow the log.
http://logs.volumio.org/volumio/QFDiZXW.html
I don’t know what else to try. I’ve got sound using the analog exit of the raspbi, that’s everything I can get.
PS. Hooked up the old Piano 1.1. It has an analog exit (headphones). I’ll try if it works.
EDIT: Analig exit (headphones) of Piano 1.1 doesn’t work either. The only way I can get any sound is using the headphones exit of the Raspbpi (Model 3.b).
Then it should be something related to the i2S…
Two other things to test…
-Disable audio resamling in playback setting
-try with FusionDsp enabled
It took a while to install FusionDSP plugin, but I’m afraid doesn’t work.
I’m considering to buy a new raspberry pi, and old 2nd hand pi3b considering I’m ok with this configuration and see if I can’t get a reduced price… The thing is, raspberry pi seems to work fine either way
SOLVED!!!
Malfunctioning of the I2S pins of the raspberry… I swapped raspbi3b with another one I usually employ with Kodi and HDMI hooked to a TV. Since this one doesn’t use the pins, it could save my day.
And that’s right, hooked kali+piano2.1 with the other raspi and everything works. And on the other hand, the damaged raspi with faulty i2s pins, works for it’s role: playing NAS files through LAN over HDMI port hooked to a TV.
Thanks balbuze and judydudi for the help!
