Raspberry 7" display on RPi4
Hey @gvida,
Volumioconfig is clean - Pi Screen Setup did strip the conflicting display directives correctly. So the on-disk configuration is in order.
Yet the kernel is not binding the vc4 KMS driver. To narrow this down, please SSH in and paste the output of these four commands:
  1. ls /dev/dri/
  2. cat /boot/cmdline.txt
  3. ls /boot/overlays/vc4-kms-v3d-pi4.dtbo /boot/overlays/vc4-kms-dsi-7inch.dtbo
  4. sudo dmesg | grep -iE "vc4|drm|dsi|kms|bcm2708_fb" | head -40
volumio@volumio:/$ ls /dev/dri/
ls: cannot access ‘/dev/dri/’: No such file or directory
volumio@volumio:/$
volumio@volumio:/$ cat /boot/cmdline.txt
splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=serial0,115200 console=tty1 imgpart=UUID=9caf6474-168f-4972-add4-ace36a467bc2 imgfile=/volumio_current.sqsh bootpart=UUID=807D-2966 datapart=UUID=bea3e05c-62cf-4b22-a58d-66213927f56a uuidconfig=cmdline.txt rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no cfg80211.ieee80211_regdom=FR fbcon=rotate:0volumio@volumio:/$
/boot/overlays/vc4-kms-dsi-7inch.dtbo /boot/overlays/vc4-kms-v3d-pi4.dtbo
volumio@volumio:/$ sudo dmesg | grep -iE “vc4|drm|dsi|kms|bcm2708_fb” | head -40
[sudo] password for volumio:
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 numa=fake=2 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:AE:BF:37 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=9caf6474-168f-4972-add4-ace36a467bc2 imgfile=/volumio_current.sqsh bootpart=UUID=807D-2966 datapart=UUID=bea3e05c-62cf-4b22-a58d-66213927f56a uuidconfig=cmdline.txt rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no cfg80211.ieee80211_regdom=FR fbcon=rotate:0
[ 0.000000] Unknown kernel command line parameters “splash nodebug numa_policy=interleave numa=fake=2 iommu_dma_numa_policy=interleave imgpart=UUID=9caf6474-168f-4972-add4-ace36a467bc2 imgfile=/volumio_current.sqsh bootpart=UUID=807D-2966 datapart=UUID=bea3e05c-62cf-4b22-a58d-66213927f56a uuidconfig=cmdline.txt bootdelay=7 use_kmsg=no”, will be passed to user space.
[ 1.345179] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.348135] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 800x480
[ 1.902599] use_kmsg=no
[ 17.651410] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm…
Hi since the logs a sent you i did not get any response from you.
Is there a way to help me for resolving my issue?
I count on you
Thank you very much.
@gvida
Just be patient, also @nerd is doing this in his free time.
Hey @gvida,
To move forward we need to reset the display stack and isolate one plugin at a time. Please do the following, in this order.
  1. Open the Now Playing plugin settings. In the “Volumio Kiosk (Local Display)” section, switch the kiosk target back to the Touch Display default (undo the earlier “Set to Now Playing” action). Save.
  2. In Plugins - Installed Plugins, disable the following so the button reads OFF:
    • Touch Display
    • Now Playing
    • System information
    • FusionDsp
    Leave Pi Screen Setup enabled.
  3. Reboot from the web UI power menu.
  4. After the boot completes, look at the 7" display. Report which of the following you see:
    a) The Volumio boot logo followed by the tty1 console with the QR code and IP address
    b) The Volumio boot logo and then a black screen
    c) No Volumio boot logo at all
If (a) - enable only Touch Display from the plugin page, reboot, and after boot post two things:
Paste the full output.
If (b) or (c) - report which of the two, and stop there. Do not enable any further plugins.
As @Wheaten pointed out - please be patient.
HI nerd
Sorry If you considered I was not patient, this was not at all what my message wanted to be. I really appreciate your support and job you all do.
going to the now playing plugin as you can see I have an error message “kiosk script not detected”, so I cannot do any switch as suggested.
May I have to poursuit to the next steps 2 and then …
Sincerly yours
Georges
HI these are the steps I did.
set off
  • Touch Display
  • Now Playing
  • FusionDsp
reboot
back to plugins page, touch display is set on automatically (no action from me)
Hi in addition when switch off touch-display I get this error message.
I also tried to uninstall it, but get the error and the plugin does not diseaper from the pluging list.
Hope this will help.
Hi all.
I don’t want to start new thread so I’m writing here.
The issue I have is touch offset on a fresh install of Volumio 4.
I have been using Volumio 3 on RPi 4 with Official RPi 7 inch display v 1.1 for years and everything was great.
Now I decided to switch to Volumio 4 using same setup and I got into the issue with touch offset.
There is fresh install of Volumio 4 (Balena Etcher software used to prepare SD card so no initial cfg from Rpi Imager) and there is only one plugin istalled - Touch display v 3.6.
Log: http://logs.volumio.org/volumio/YGkaXjO.html
Volumio version: 4.119
Raspberry Pi version: 4B v 1.1
Display version: RPi 7 inch v 1.1 display
userconfig.txt:
disable_hdmi=1
dtoverlay=vc4-kms-v3d,nohdmi
I found here [PLUGIN] Touch Display - #1768 by Kampf_Keks_3000
that those 2 lines added can fix the issue but it doesn’t work for me.
Offset gets bigger when touching more on right side of the screen.
Any ideas how to fix an issue? @nerd @Wheaten
HI
I created a new memory card and did a fresh installation. I do not know why, but volumio works now as expected.
Sorry for that, thanks for your support anyway.
Georges
