I have been using volumio for quite a while on two raspberrys (raspberry 3 with hifiberry dac pro)
One did not work properly since mid of January and I was using the other one instead. But then the other was constantly restarting again. So I had to try to look for a solution and I was using the latest volumio image. But on both of them after the last update to Volumio-3.631-2024-02-21-pi Volumio does not read the inserted hard disk, even though via windows explorer I can see the hard disk and its folders of my music. I cannot start the store, so there are no plugins.
I did not use etcher for writing the sd card but the raspberry sd card writer.
Randomly both systems tell me “volumio konfiguration aktualisieren wiedergabegerät erfolgreich gestartet”, but I cannot make any configuration.
FusionDSP yields FATAL ERROR. Either disable it and test again or revisit parameters an update accordingly.
Second Raspberry Pi3:
Note: Illegal Audio-MPEG-Header 0x00000000 at offset 316. Note: Trying to resync... Note: Hit end of (available) data during resync. Mar 10 08:00 : mpg123: mpg123_getformat() failed: Message: I am done with this track. Mar 10 08:00 : ffmpeg/mp3: Format mp3 detected only with low score of 1, misdetection possible! Mar 10 08:00 : ffmpeg/mp3: Failed to read frame size: Could not seek to 1343.
eventually gives up.
Perhaps updating to latest test image would help with the second case: http://192.168.178.33/dev
Enable Test and accept update.
the test mode thing seems to have solved everything with my …33 raspberry,(the second) - at least I was able to install plugin, have a look at the hard disk.
while with the first raspberry (…54) after deinstalation of the dsp plugin there is the ongoing problem as with the other one, I will enable the test mode aswell,
