Hey all,
Volumio Version: 2.882 and backward versions
Hardware: Raspberry Pi 3B
DAC: HifiBerry Digi-Pro
I cannot for the life of me get Volumio to boot and load with any other version than 3.073, whenever I use any older version I’ll flash it to the card, turn on the Pi get one green light flash then nothing at all.
However with 3.073 works a treat every time, no problem booting or restarting, recognises the Hifiberry hat and any connected media. However, I’d quite like access to the plugins for Spotify connect so want to get an older version working.
The current workflow for any older version is as such:
- Clean card and create a partition using Diskpart
- Use Etcher in flash 2.882, 2.878 or 2.873
- Card into Pi, power up (checked PSU no under-voltage warning)
- Activity light flashes once then nothing
- Screen shows no activity
Having run through the previous posts with similar issues I’ve tried most of the workarounds they suggest but with no luck. For sake of sanity, I have just redownloaded a fresh 2.882 gone through the whole process as exactly as instructed in the manual and no luck sadly.
I’m at a loss as to why 3.073 works no issue but any other will not install whatsoever so greatly apprecaite any help!
Cheers,
Nick
