Loving Volumio, and i continue to upgrade my stereo around the Volumio Streamer which has been phenomenal. Now thinking about a significant purchase, ie the PSAudio Stellar Gold Dac,
In this case USB connection seems the most streamlined bet.
HDMI suitability would depend on other elements of the hardware / software involved, but as it’s designed for signal-out on the Pi4b, it should work for audio in the right program(s).
The DAC itself seems disproportionately “excessive”, but that’s at least as much opinion as it is fact.
Yes. I agree with you. Performance with I2s input is as good as the source is. In this case I2s is only one of the Kernel process. Much better is send to DAC signal via USB and all process will be prepared with special processors in DAC.
I have hearing difference between Pi + I2s card and Pi + USB card to DAC.
In my system, each element is matched and tuned to each other (I won’t talk about prices because sometimes my wife reads what I write ) and I2s with Pi showed sound degradation.
In this DAC he has : I2S, USB, AES/EBU, coaxial inputs. I2S will be good if use with streamer like Rose or Lumin where I2s is hardware.
Stellar Gold DAC is very good 8 x ESS dual mono ( 4 x ESS 9038 per chanell gives better THD and NSR parameters ). You get from DAC what you give to DAC. ( I repeat that is my opinion ) I2s from Pi is not enought good signal for this DAC.
The stones can be transported by truck and can also be transported by bicycle. The choice is yours
