I tried to enable. But, would not allow me to. It does say “active”
All it shows on my screen is volumio login:
Which it does every time it starts. Is there a way to have it not start asking for login each time? I read something about SSH but this may all be above my head.
This may all be beyond me. I’ve opened up Terminal as advised here… just not seeing how Terminal, SSH, Volumio and the Rasberry all relate to each other.
I did try to “disable” SSH on the Volumio Test Player page but does not seem to have any impact.
All what is needed is given in de links and instructions. If you not able to work through them, the rPi might not be a good choice for you. As this are pretty basic things you need to master.
Yes, you are correct Wheaten! Trying to explain this to me is like trying to teach a 5 year old how to land a plane, this is WAY beyond me. BUT, by some miracle, the touchscreen plugin worked on both of my Rasberry Pi devices so I must have done something right… maybe just re-installing. AND… I believe I know why my FLAC files are messing up, the stereo FLAC play fine, but the multichannel FlAC are garbled. i believe that Volumio is for stereo only. These are 5.1 channel SACD FLAC files. Thank you very much for your help
