hi, I mounted an allo boss on my rasp 4 (4gb) but I can’t get it to work, the system cannot find the dac. I formatted the sd card twice and redone the installation of the last image found online without success
tips?
tnks
Nothing Nothing?
[emoji3]
Inviato dal mio SM-N975F utilizzando Tapatalk
Are you sure Allo works with a RPI4?
I just purchased one and in the Amazon link there is clearly written “works only on RPI 2 and 3”, see below:
amazon.it/gp/product/B06Y2D … UTF8&psc=1
I can confirm that mine combo (RPI 3+ and Allo Boss) works fine, I’ve just some big issues in working with file on my NAS.
Regards
Massimo
Ciao
I returned that dac taking a new one (I got a ver. 1.5 ) and it worked on the first start … It was a problem of the first arrived
Main is version 1.2, I think it depends on that. Curious that also Allo.com site still displays version 1.2, where did you get version 1.5 from? And do you have any idea about differences between 1.2 and 1.5?
Regards
Massimo
Taken both on Amazon, I have no idea about the differences they don’t talk about it anywhere
