running version 2.246
have an issue that load up a queue with a few playslits from spotify
run the playlist, and then we find that randomly it will just keep playing the same track over and over again.
we have played with buffer settings to see if perhaps it was a lack of memory or something… it is running on a raspberry pi 3
Probably this issue??
This should have been fixed in the version 2.282 and was hopefully taken care of by this: https://github.com/volumio/Volumio2/pull/1290 I hope so.
…and yesterday we got 2.296, I have to check that out.
Regards, CB
Thanks guys for your help!
I will download 2.296 and hopefully the sometimes problem goes away… it was strange as it was just happening randomly.
Adam
ok just downloaded the latest 2.296.
loaded up the queue with multiple spotify preset playlists to go all into one queue… and it got stuck again repeating the same song…
have tried to click the repeat button on or off, and also the random button on and off - to no luck…
The issue is still in 2.348, it is annoying.
2.348 was released ~22 Dec 2017. What about testing with more recent version? Latest is 2.389.
Just tested this again and the problem still exists in version 2.444
Any clues?
