after a few teste … it is in fact NOT working.
The queue window is not managing and reading the TAG from the files correctly … ? It lists the track according to the file name only, or randomly … :-/
It is working when the file name is formated as “%track% - %title%” for exemple …
So the browser reads and display the correct TAG from the file, but the queue window lists the track randomly …
Is it a known bug or am I the first one to report it ?
I guess people are mostly using spotify … pitty because your system can really deliver much much more …
I had the same problem, this is how I found the thread. I am using a mobile app to control it and the UI could be improved. The Random, Repeat, and Consume, when active, become just a few shades darker compared to when they are not active. You have to toggle the on and off to see how subtle the indication is. So just check to make sure you are not in the random mode.
Had the same issue but did not ask for help.
As said before, the development of the Volumio UI will never end…
[b]Just rename all your files with an ‘0’ prefix to single numbered tracks:
1 - title.flac -> 01 - title.flac
You can use a tag editor to process files names.
EasyTAG (for Linux) does it very well[/b]
And then rescan your library (and wait : there is no sqlite library with Volumio)
And then review your playlists (no Volumio process will do it)
And your favorites too (Same thing)
Be aware to the track# id tag too.
With 2 digits or not dunno if Volumio does handle this tag for queue
As text or as integer.
Dunno what Volumio will do with track numbers it in the future
But be prepared to always rescan your library and rework all your playlists
That is sad i know…
