HI
I created a new playlist and imported in soem albums I would like to listen on random.
On that screen copy, as you can see the button random is not activ. How to set random on a playlist
HI
The playlist is displayed in the order you created it in. With the random play icon on, it will play randomly from that list (though usually the first track plays first).
Ok so why the icon is not on ?
Green is on, white is off
white is when random has been activated, correct ?
Green => Random ON
White => Random OFF
ok, this not obvious! white is like a led on, that means that the action is activated. here is the opposite, white means not activated! when we know we know but …
However thanks for the quick help
