I have a 2 line LCD screen on my set up and it displays music files names fine, but on web radio is set as unknown, the Artist and Song title are shown but the station name is not. Does anyone know how to add the names?
nice to read that you have also add a LCD to volumio.
I am working with a 16x2 LCD and did like you with AndyPi.
If I use the webradio stations that comes with volumio the first row shows “unknown” and the second row shows Artist - title in flow.
Did you try radio stations with m3u playlists (instead of pls) like this: #EXTM3U #EXTINF:-1,Sample artist - Sample title link/to/radio/station #EXTINF:-1,Example Artist - Example title link/to/radio/station2
Maybe m3u will show more informations on the LCD.
Second try: replace “Sample artist - Sample title” with the station name.
I tried your solution and it still comes up unknown, but changing the MPDLCD.conf from artist to name, makes the radio station name appear. Though this then makes another issue if you listen to you music collection through Volumio as no artist is now displayed. I am searching for a way to add an artist tag on the m3u file but none seem to work thus far.
update, I have found that within command line entering this code mpc playlist -f “[%name%][%artist%]” displays what I require, basically it shows either the artist name or the station name, but leaves this blank if there is no tag. It works, but when listening to my tracks the artist and track name now show as one work, so its getting closer to a fix but not there just yet.
