Since the recent updates, I’ve been unable to play from the Radio Paradise Plugin in any format. The player spins for a second then reboots.
Rpi 3B with Hifiberry Amp 2.
From the log file:
Sep 28 20:12:29 pifi volumio[894]: info: [1538165549073] [RadioParadise] getStream started with url http://api.radioparadise.com/api/get_block?bitrate=4&info=true
Sep 28 20:12:29 pifi volumio[894]: info: [1538165549347] [RadioParadise] Failed to query radio paradise api, status code: 301
Sep 28 20:12:29 pifi volumio[894]: |||||||||||||||||||||||| WARNING: FATAL ERROR |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Sep 28 20:12:29 pifi volumio[894]: ReferenceError: station is not defined
Sep 28 20:12:29 pifi volumio[894]: at ClientRequest.http.get (/data/plugins/music_service/radio_paradise/index.js:396:26)
Sep 28 20:12:29 pifi volumio[894]: at Object.onceWrapper (events.js:315:30)
Sep 28 20:12:29 pifi volumio[894]: at emitOne (events.js:116:13)
Sep 28 20:12:29 pifi volumio[894]: at ClientRequest.emit (events.js:211:7)
Sep 28 20:12:29 pifi volumio[894]: at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:551:21)
Sep 28 20:12:29 pifi volumio[894]: at HTTPParser.parserOnHeadersComplete (_http_common.js:115:23)
Sep 28 20:12:29 pifi volumio[894]: at Socket.socketOnData (_http_client.js:440:20)
Sep 28 20:12:29 pifi volumio[894]: at Socket.emit (events.js:211:7)
Sep 28 20:12:29 pifi volumio[894]: at addChunk (_stream_readable.js:263:12)
Sep 28 20:12:29 pifi volumio[894]: at readableAddChunk (_stream_readable.js:250:11)
Sep 28 20:12:29 pifi volumio[894]: at Socket.Readable.push (_stream_readable.js:208:10)
Sep 28 20:12:29 pifi volumio[894]: at TCP.onread (net.js:607:20)
Sep 28 20:12:29 pifi volumio[894]: |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Sep 28 20:12:30 pifi sudo[1295]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl --since=2018-09-28 20:11
Sep 28 20:12:30 pifi sudo[1295]: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 28 20:12:30 pifi sudo[1295]: pam_unix(sudo:session): session closed for user root
Sep 28 20:12:31 pifi systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Sep 28 20:12:31 pifi volumio-remote-updater[541]: [2018-09-28 20:12:31] [error] handle_read_frame error: websocketpp.transport:7 (End of File)
Sep 28 20:12:31 pifi volumio-remote-updater[541]: [2018-09-28 20:12:31] [disconnect] Disconnect close local:[1006,End of File] remote:[1006]
Sep 28 20:12:31 pifi systemd[1]: Unit volumio.service entered failed state.
Sep 28 20:12:31 pifi systemd[1]: Starting dynamicswap service...
Sep 28 20:12:31 pifi systemd[1]: Started dynamicswap service.
Sep 28 20:12:31 pifi systemd[1]: volumio.service holdoff time over, scheduling restart.
Sep 28 20:12:31 pifi systemd[1]: Stopping Volumio Backend Module...
Sep 28 20:12:31 pifi systemd[1]: Starting Volumio Backend Module...
Sep 28 20:12:31 pifi systemd[1]: Started Volumio Backend Module.
Sep 28 20:12:33 pifi volumio[1319]: info: -------------------------------------------
Sep 28 20:12:33 pifi volumio[1319]: info: -----            Volumio2              ----
Sep 28 20:12:33 pifi volumio[1319]: info: -----          System startup          ----
