Hi all. After listening to Radio Paradise for the past year via Volumio I am no longer offered the alternative mix option at at 16/44.1Hz bitrate. Is this a) a licencing issue with Volumio b) a Radio Paradise change or am I missing something in the settings? Help would be appreciated as streaming lossy formats is killing me softly.
Do you use the RadioParadise plugin?
I do, and I realised that it had somehow been switched off. Switched it back on and all good now. All options in RP showing up.
Thanks for the response.
Hello, I will be upgrading my streamer to a Volumio Rivo+. With the Radio Paradise plugin, can you stream Flac files, and are you able to see album artwork at all? Also, are you able to switch to the next song on a playlist?
Thank you,
Keith
The RP plugin will show cover art and metadata. You can’t skip as it’s a radio stream not a playlist.
I was curious because I currently have a bluesound NODE, and with that device you are able to skip ahead. Thank you for your reply. ![]()
