Hello ,
I have installed latest volumio version in rpi4 . After a pause , if I play radio , radio does not start . I have tried also to switch the radio but still not ok .
I installed only peppy spectrum , touch display , radio paradise
In order to fix I need to do a restart .
I’m afraid the radio or some decoder has a memory leak. I’ve tried leaving the radio stations playing for days and they freeze. Apparently 256 kbps radios hang at half the time of 128 kbps radios. I’ve tried with other Linux distributions and it doesn’t happen.
Volumio should seriously consider discarding Armbian with DietPi.
Thank you. I noticed the defect only with Raspberry Pi, it is easily reproducible, play this station https://www.gammaradio.it/ at 256 kbps, go to sleep and tomorrow you will find it blocked. With the Raspberry Pi Zero W it always happens.
I tried with DietPi and Firefox to do the same test, the memory used increases with playback time to about 600MB and then decreases around 500MB. Probably DietPi uses less RAM but I used Firefox too, Volumio has no graphical interface and the hardware starts from 512MB of RAM.
The new version 3.601 of Volumio seems to have solved the problem, https://www.gammaradio.it/ no longer freezes during playback.
On computers with 512 MB of RAM a swap file has been added and the free memory remains approximately constant, on models with 2 GB of RAM there is no swap file and the free memory still decreases by about 1 MB every 20 minutes.
Under these conditions we should have about 3 weeks of guaranteed reproduction. I hope I haven’t written nonsense.
in the new stable release 3.601 we finally managed to include an updated version of MPD, after fixing several other regressions introduced by this change.
I think this was the change that made your problem solved
