Questions about the new Primo Plus
I am considering an order for the new Primo Plus, and need a few questions answered first:
  1. Does the Primo Plus support Qobuz Connect?
  2. Can I used the RCA and Balanced outputs at the same time? I’d like to go balanced out to my power amp and RCA out to my subwoofer.
3.Can I use the Lineo5 power supply with the Primo Plus?
Thank-you.
hi
  1. yes, Qobuz Connect is supported
  2. yes, they are active simultaneously
  3. yes, Lineo5 with Primo Plus is a killer combo :sunglasses:
Thank you Darnur. Just what I was looking to hear. Cheers!
You’re welcome! I’m sure you’ll love it
