Volumio Information
Volumio Version: 2.882
Hardware: PI 4, 4GB
DAC: DigiOne Signature
I looked it up (no luck) and submitted a bug right away but it is so much of a pain in the butt for me that I had to address it right away.
I am trying to open “My Tracks” (QOBUZ) and it fails systematically with “Error No result” and I really rely on that feature for obvious reasons…
Here below is the log:
info: CoreCommandRouter::executeOnPlugin: qobuz , handleBrowseUri
info: handleBrowseUri took 771 milliseconds
error: Failed to execute browseSource:
It came out of nowhere and was also messing with “My Playlist” initially but after a reboot this came back but no luck for “My Tracks”…
So can I get “A little help from my friends”?
Seems an issue either with Volumio or Qobuz. I am able to play Qobuz tracks but, even Qobuz own playlists are failing.
Are you saying that you have the same kind of issue but for you Playlists are the unreachable ones?
Hey @Wheaten try to add a new playlist and tell me if it “fixed” your issue.
I just added a new track to My Tracks. Unlocked the feature. What the…
Anyway, that works now…Can’t say for how long though…
Sorry for the late reply, occupied finalizing my pre-amp.
I don’t create playlists with Qobuz. I use smart playlists from JRiver as they can be used dynamic, like give me all pop songs from the eighties in random order, max 5 songs per Album Artist and only 2 songs per album.
But I see the playlist provided by Qobuz are also working again,
Well, whatever floats your boat
Just got back from a long week-end during which Qobuz (and this time, I am talking about the Qobuz Android app) went haywire. Couldn’t play any album without it stopping all the time for no reason… It is now back in order. So I guess this was never a Volumio issue…
Anyway, case closed!
