Qobuz integration stopped working
My Qobuz integration has been working fine since updating to V3 for weeks. I haven’t used it in a couple days, but today I got several errors on both my Pi streamers and can’t get it working. I am using Pi 4’s with most recent update 3.179. I have rebooted them, rebooted my router. No change.
When I try to select Qobuz as a source the first time, it disappeared and gave me a no results found error. I tried logging out of Qobuz and back in under Sources, but it won’t let me log back in. I get a domain error and I have to reload to get back to the Pi interface. I tried toggling My Volumio off and on. This is on both my players, in the Android app or the web interface.
Log
http://logs.volumio.org/volumio/X8AE362.html
Does it mean you can’t login anymore on any device, or just volumio?
If it’s only related to Volumio, I would suggest a fresh install.
Yes, only on Volumio. It’s definitely a Volumio issue and not Qobuz. Why would I need to fresh install on both devices? Seems weird that both would do the same thing if it were an install issue. I already did new installs when I went to V3, and it’s been working for weeks. No new update applied either, just started happening today on both my Pis. I’ll do fresh installs if I need to
Just take a fresh SD and perform the setup, If Qobuz connects, you know it related to the SD. SD can be near EOL, or just a bad spot during flash or upgrade.
if you still can’t connect, we need to look at something else.
You’ve been unlucky enough to use QOBUZ during a 40 minutes outage on our servers.
Now the situation is back to normal. sorry for the issue.
For everyone interested, you can check the status of volumio servers in this page:
https://status.volumio.com
Ah yes it’s back. I’ll mark the status page for if this happens again. Thanks.
I´m new in Volumio and did my installation yesterday and I have a error “Internal Error” page every time I try to activate Qobuz native in Volumio UI. For Tidal ok.
