<!-- Welcome to the Help and Support category
I've had a Virtuoso account since January 2020 using Qobuz via volumio. Now, the Qobuz plugin has disappeared and does not show up in the plugin search list. Has Volumio ceased their integration with Qobuz?
Check in settings sources. You should see Qobuz toward the bottom, just after Tidal.
Qobuz is not a plugin. Check if you’re connected to myvolumio, and in source, check if qobuz is enabled (credentials).
