I have an album I purchased and downloaded from Qobuz that I get a fail to decode error message when I try to play it from my Music Library. If I access it from the Qobuz plug-in, it will play. Other Qobuz downloaded albums seem to work fine from Music Library. I’m running v2.917 on a Pi2AES hat on a RPi4. Any suggestions on what’s going on here and how to correct it?
- Restart Volumio device to clear current logs
- Play the album that triggers the error
- Submit a log
- Paste the link to the log here and also state the title of the song that you’re trying to play
http://logs.volumio.org/volumio/VQxcIzC.html
The song title is Made Man
4 end points timed out.
Failing endpoints:
https://oauth-performer.dfs.volumio.org, 703 ms
https://browsing-performer.dfs.volumio.org, 703 ms
http://cddb.volumio.org, 703 ms
http://plugins.volumio.org, 703 ms
Nov 18 05:32 : ffmpeg/wmalossless: Bit-depth higher than 16
Nov 18 05:32 : ffmpeg/wmalossless: is not implemented. Update your Libav version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
Nov 18 05:32 : ffmpeg/asf: max_analyze_duration 5000000 reached
Nov 18 05:32 : ffmpeg: Could not open codec
Nov 18 05:32 : exception: Failed to decode NAS/NAS/Guided By Voices/Earth-Man-Blues/1_1_Guided-By-Voices_Made-Man_2.wma
Nov 18 05:32 : player: played "NAS/NAS/Guided By Voices/Earth-Man-Blues/1_1_Guided-By-Voices_Made-Man_2.wma"
The ffmpeg library on v2.917 is probably too old. I would suggest you try Volumio 3 RC.
That did it. Thanks!
