Qobuz Connect stuttering @ CD 16bit 44.1kHz
Volumio Version: 3.832
Hardware: RPI Zero 2W
DAC: Allo BOSS
All tracks with 16bit 44.1kHz are stuttering massiv over Qobuz Connect,
clients @ WebPlayer, OSX, IOS + Android all the same; playing the same tracks locally with Qobuz ‘Inline’ are ok.
HiRes tracks up to 192kHz with Qobuz Connect are ok too.
Qobuz Connect stuttering:
volumio@volumioboss:~$ volumio status
“status”: “play”,
“title”: “Unity”,
“artist”: “Nina Hagen”,
“album”: “Unity”,
“albumart”: “https://static.qobuz.com/images/covers/ca/kd/dz758jkyikdca_600.jpg”,
“uri”: “”,
“trackType”: “qobuz”,
“codec”: “”,
“seek”: 0,
“duration”: 213,
“samplerate”: “44.1 kHz”,
“bitdepth”: “16 bit”,
“channels”: 2,
“random”: false,
“consume”: false,
“volume”: 100,
“dbVolume”: null,
“mute”: false,
“disableVolumeControl”: false,
“stream”: false,
“updatedb”: false,
“volatile”: true,
“service”: “qobuzconnect”
same track @ Qobuz inline not stuttering, ok:
“status”: “play”,
“position”: 2,
“title”: “Unity”,
“album”: “Unity”,
“uri”: “qobuz://song/190045726”,
“seek”: 4509,
“duration”: 213,
“channels”: 2,
“bitrate”: “833 Kbps”,
“random”: null,
“repeat”: null,
“repeatSingle”: false,
“consume”: true,
“volume”: 100,
“dbVolume”: null,
“mute”: false,
“stream”: false,
“updatedb”: false,
“volatile”: false,
“service”: “qobuz”
edit: trackstatus copy corrected
the same behaviour wtith
Hardware: RPI 4B 8GB
DAC: ifi NEO iDSD2 (extern USB)
Update to Volumio Version: 3.845
no changes.
I have the exact same problem.
DAC: Allo Boss2
I had the same issue on my Primo, today I updated the FusionDSP plugin and now seems working
@Luki_Vents solution did not work for me, but Disabling or Uninstalling the FusionDSP plugin made the problem go away.
Now I cant use my parametric filters, tho
Just checking in to see if anyone has solved this problem in order to use FusionDSP and Qobuz Connect
so still the same behaviour wtith
Volumio Version: 4.073
FusionDSP: 2.077
Hardware: RPI 4B 2GB
DAC: NanoSound DAC 2
hello!
By waiting a fix, try to disable multiroom in sources
:wink:
hi,
it works, thx ;-D
