QOBUZ Connect for Volumio
Since there is a lot of people who use QOBUZ also, it would be great to have QOBUZ Connect integrated into Volumio as well.
This is especially beneficial if music is being streamed with Apple device (iPhone, iPad) since if you stream to Volumio with Airplay, it will be degraded to 44.1.
With QOBUZ Connect (which works the same way as Spotify Connect or Tidal Connect) Airplay is bypassed thus allowing to listen higher then “red book” sample rate…
Will close this post in favour of the already open one :slight_smile:
