hello!
please reboot the router and give it a try
Best,
Davide
VOLUMIO TECH SUPPORT
hello!
Best,
Davide
Good morning Davide,
The issue persists. Have a great weekend. Thank you.
Hello!
About Spotify, could you please log in to the Spotify plugin in Volumio and then try again to discover the device using Spotify Connect from the Spotify app?
Davide
@DED,
Can conform the same on the Rivo.
When Qobuz connect is used, moving to Spotify Connect the Rivo keeps playing the Qobuz track. It will show the Spotify meta data, but still playing the Qobuz track, even with the Qobuz app terminated. (iPhone)
Hi Davide,
I tried the below:
I hope these help.
is there a way to rollback to a non-Qobuz Connect fw version? or any other trick?
thank you
Unfortunately, there is no way to downgrade to a previous software version.
In the meantime, we are digging deeper into the issue to better understand what’s causing it.
Thank you for providing all the details, they are very helpful.
Best
Davide
Good luck. thank you for your support
Hello, I did a reset and all works fine now. sorry for the troubles. thank you.
I use the last version, install TOUCH Display and Now Playing. I have both account TIDAL and Qobuz when only use TIDAL Connect
It starts playing. When use several time next track it freeze. Also when go back in tracks several times it freeze. When switch between
TIDAL to Qobuz it freeze also
I hope this help find a solution
hope that this help!
When select Playback Mode “single” everything seems to work !!!
I’m testing it for several hours
Regards
Qobuz connect for the Rivo+ is working for me on both my IPHONE and my old IPAD air. Performance seems to be very good. I have not checked “beginning of tracks being cut” issue, since I am working, and I have the volume off.
Ok, I got it to “forever spin”. I had my Iphone on Qobuz, and my IPAD on Volumio, and I tried to go back and forth controling the Rivo+ with both apps. I easily got it to “spin” with no response. BTW, as expected, if you have a 4K screen hooked up to the Rivo+ HDMI, it always shows the Volumio UI when you are using Qobuz connect.
@DED Hi Davide, Volumio sometimes broadcasts the Connect availability to the network but does not start playing. or even does not broadcast the Connect (Spotify, Tidal and Airplay) at all. The issues gets fixed when I resave the Output Device where it says “Player Successfully Restarted” This happens more often when jumping from connect protocol to another. If USB is selected, the problem is twice as big. Is it possible to integrate an auto Player Restart at each Connect switch in a future update(or whatever else is triggered by resaving the output device)? I can imagine this will introduce a delay, but maybe it can be optional in the settings? thank you, best
