Hello. I used to use PuTTy commands to install plugins in ZIP format. Unfortunately, I haven’t used raspberry for a long time, and now I need to install them. Can you write what commands to type? I know that the file in ZIP format should be moved in Filezilla to Raspberry and then copied to the clipboard.
Register a free account with myvolumio and install everything via the plugin store.
Prefer not to support manual install and providing unneeded support because something went wrong.
Approx. However, the equalizer plug-in is not available in the volumio store. I have the full version of Volumio active. Commands are even needed to install Peppymeter
