Putting music source in M.2 SSD
Hi
Power supply is exactly this one https://allo.com/sparky/5v-power-supply.html#features
5V - 3A. (from Xing Yuan XY24S-0503000Q-U)
PSU → Allo Kali Reclocker Barrel 5V input → Power is passed to 1) Allo Piano DAC 2.1 through GPIO & 2) Raspberry Pi 3 through GPIO → A) SSD through USB-2 & B) Wifi Dongle through USB
Power from Kali is shared through GPIO to Allo Piano Dac 2.1 on TOP & Raspberry Pi 3 on BOTTOM through GPIO.
Then Raspberry Pi 3 give power to SSD & Wifi Dongle through USB-2
Hey @laluciol6990,
Thanks for the clarification - this setup sheds light on the actual configuration, but also highlights a critical discrepancy:
The original post said:
“I own a Raspberry 5…”
But this reply describes a power chain that only applies to Raspberry Pi 3:
  • PSU → Allo Kali Reclocker → GPIO power to Pi + DAC
  • SSD + Wi-Fi dongle running off USB-2, which only exists on Pi 3
This is important because Pi 3 and Pi 5 have completely different power and USB architectures. Debugging undervoltage and USB enumeration requires knowing exactly which SBC we’re dealing with.
Action Required: Confirm Your Actual Board
Please use the following link to generate an SBC identification form:
Or run this directly via SSH:
cat /proc/device-tree/model
Expected output for Pi 3:
Raspberry Pi 3 Model B Rev 1.2
Expected output for Pi 5:
Raspberry Pi 5 Model B Rev 1.0
Once we have positive identification, we can proceed with the correct diagnostics. Power routing and USB stack behavior vary significantly between Pi 3 and Pi 5 - especially with chained devices like the Kali and Piano DAC.
Let’s confirm this before digging deeper.
Sorry for the confusion
The original poster mentioned a Raspberry model.
I joined the thread because of the M.2 SSD mounting issue, but my Raspberry Model is, according to the command you suggested: “Raspberry Pi 3 Model B Rev 1.2”
Hey @laluciol6990,
Thanks for the details. Full power path breakdown - this matches what we’d expect for an Allo stack powered via the Kali reclocker. The PSU used (Xing Yuan XY24S-0503000Q-U, 5V 3A) is within spec on paper, but the actual layout introduces multiple weak points under load:
Power Flow Analysis
[5V 3A PSU]
[Kali Reclocker 5V Barrel Input]
   ↓ GPIO
[→ Piano DAC 2.1 (top)]
[→ RPi 3 (bottom)]
        ↓ USB
      [SSD] + [Wi-Fi dongle]
This creates a single-rail, passive distribution tree with no power buffering or current prioritization. Issues:
  • SSD and Wi-Fi dongle both draw peak current from the Pi’s USB port, which itself is powered through GPIO from the Kali
  • The Pi 3’s USB power is not current-limited or isolated, so any sudden demand (SSD spin-up, Wi-Fi burst) causes a brownout across the system rail
  • No dedicated 5V injection to USB, no powered hub, and no inline capacitance
The kernel’s undervoltage warning (hwmon hwmon1) is a direct result of this design - even if average load is acceptable, brief voltage dips are enough to trigger this error.
Confirmed Symptoms
  • Intermittent device enumeration or failures (as originally seen with the SSD)
  • Potential audio dropouts under load
  • Reduced USB throughput or flaky Wi-Fi in high-bitrate streams
Recommended Fixes
  1. Use a powered USB hub for Wi-Fi and/or SSD
    • Offloads transient current draw from the Pi’s 5V rail
    • Reduces brownouts on GPIO-fed logic
  2. Inject 5V directly to the Pi’s USB rail
    • Only if you understand backfeeding and protection (not recommended unless you’ve isolated the Pi’s polyfuse)
  3. Switch to a beefier PSU with tighter voltage regulation
    • Some 5V/3A units dip below 4.75V under real load - not acceptable for USB + I²S + Wi-Fi combined
  4. Add local capacitance
    • Placing a 470µF–1000µF electrolytic cap across 5V and GND near the USB socket can dampen brownouts (hardware mod)
Further testing
One-Time Check (Snapshot)
Run this command via SSH:
vcgencmd get_throttled
Sample output:
throttled=0x50000
Then interpret the bits:
Bit Meaning Value
0 Under-voltage now 0x1
1 Frequency capping now 0x2
2 Throttling now 0x4
16 Under-voltage has occurred 0x10000
17 Frequency capping has occurred 0x20000
18 Throttling has occurred 0x40000
If you see:
throttled=0x50000
It means:
  • Bit 16 → Under-voltage has occurred
  • Bit 18 → CPU throttling has occurred
  • (no Bit 0) → Not currently undervolting
Periodic Monitoring Script
To monitor over time and log when undervoltage occurs, use this shell script:
#!/bin/bash
LOGFILE=/home/volumio/undervoltage.log
INTERVAL=60
while true; do
    STATUS=$(vcgencmd get_throttled)
    TIMESTAMP=$(date '+%Y-%m-%d %H:%M:%S')
    echo "$TIMESTAMP $STATUS" >> "$LOGFILE"
    sleep "$INTERVAL"
done
Save as monitor_uv.sh, then run:
chmod +x monitor_uv.sh
nohup ./monitor_uv.sh &
This will log entries like:
2025-04-14 21:30:01 throttled=0x0
2025-04-14 21:31:01 throttled=0x50000
You can later grep for events:
grep -v 'throttled=0x0' undervoltage.log
Thanks for so much details!
I would check to put the script in place this weekend when i have some time.
Regarding the possible solutions, i think the easiest is to buy a beefier & better regulated PSU, like 5V >4A, industrial or medical grade from Mouser/Digikey or electronic components website…
Others solutions are a bit more complex or i don’t have the necessary knowledge…
But thanks again for the pointers!
Powering the device, no music playing or anything
“throttled=0x50005”
I had to add some command because i was told
“2025-04-26 08:43:52 Can’t open device file: /dev/vcio
Try creating a device file with: sudo mknod /dev/vcio c 100 0”
I did it on the terminal
But then, for the script, i am a bit at a loss to make it working while trying to integrate the mknod…(i am not a programmer / used to bash scripting)
Hi
Some updates, if situation could be further improved…
  1. I got a better power supply, capable of 5V 6A Mouser Link
    When i ran with this power supply, i got the same “throttled=0x50005” from the vcgencmd command
    (May 2nd)
  2. This morning (May 3rd), i connected both the new power supply 5V 6A as previously, and connected the mSata board with Micro-USB for additionnal power (now connected through USB for data & power to Pi and Micro-USB for additionnal power)
    Same “throttled=0x50005”.
  3. Log file here http://logs.volumio.org/volumio/rwjfWEr.html
  4. Only when i unplug the SSD, i have “throttled 0x50000”.
Not expecting specifically an answer, but if somebody know how to improve further…
(will look into the capacitance thing)
More updates on 05/04/2025
  1. To avoid throttling, one way was:
    a. remove a jumper on Kali board to separate power between Kali & Raspberry Pi
    b. connect 5V 6A PSU to Raspberry Pi through Micro-USB
    c. connect 5V 3A PSA to Kali board
    This is a 2 PSUs solution, a bit cumbersome so i will see if i can create a specific cable to have the 5V 6A PSU power Raspberry Pi through Micro-USB & Kali through barrel connector
  2. One question to @nerd : Could i try to solder the capacitor on the GPIO direclty where the power from Kali would come from originally (5V & GND)?
  3. Just for reference: this page https://blog.mccormack.tech/shell/2019/01/05/monitoring-raspberry-pi-power-and-thermal-issues.html helped me greatly interpreting the vcgcmd command results
Have a nice day
Last set of updates: 16/05/2025
PSU 5V 6A with a split cable: 1 wire going to Allo Kali (without the jumper, so Kali doesn’t power the Raspberry Pi anymore), 1 wire going to the Raspberry Pi (powered through micro-usb port)
I get “throttled=0x50000” with the SSD connected
I will let it at that
