Good afternoon!
Dear @nerd,
I have to state: this is a masterpiece!
Congratulations and many, many thanks for your countless effort and your huge engagement on this!
Today I was able to install your latest bookworm alpha release and it works like a charm.
System Information:
OS info
Version of Volumio: 0.061
Hostname: korellmusik
Kernel: 6.6.62-v8+
Governor: conservative
Uptime: 0 days, 0 Hrs, 13 Minutes, 42 Seconds
Network info
Interface: wlan0
IP Address: xx.xxx.xx.xx
MAC Address: 2c:cf:6xxxxxxxx2
Type: wireless
Speed: nullMb/s
Audio info
Hw audio configured: HiFiBerry DAC2 Pro [Pi5]
Mixer type: Hardware
Number of channels: 2
Supported sample rate: 22050 44100 48000 88200 96000 176400 192000
Board info
Manufacturer:
Model: Raspberry Pi 5 Model B Rev 1.0 / /
Version: d04170 /
Firmware Version: 2025/02/12 10:51:52 version f788aab6 (release) (embedded)
CPU info
Brand: BCM2712
Speed: 2.4 GHz
Family: Cortex-A76
Model: 1
Number of cores: 4
Physical cores: 4
Average load: 23%
Temperature: 55°C
Memory info
Memory: 8147960 Ko
Free: 6219580 Ko
Used: 1928380 Ko
Software info
Mpd version: Music Player Daemon 0.24.3 (0.24.3)
Storage info
INTERNAL storage - Size: 54317Mo
Used: 1328Mo
Available for storage: 50095Mo (92%)
Additional Hardware in my setup:
HifiBerry DAC2 pro is listed above in system information.
In addition I have connected:
System installation went without any issue - Hotspot was created and I could connect, configure and restart. To my pleasure the locally connected display worked immediatly - without any additional step and shows up Volumio Logo and startup message (this in wrong direction, but this doesn’t matter to me)
Plugin installation first went wrong - by my own fault because I was confused and forgot to enable plugin-test-mode - which is clearly advised by you.
Second attempt went without any issue, as well.
I’ve installed the following plugins (in their respective order):
- Touch-Display - works including correct screen rotation and touch-functionality
- Spotify - works immediately
- Rotary Encoder II - same config as before - works without any issue
- Now Playing - Works out of the box
- System Information - works (output above in System Information)
The BT remote connection was easy as on Buster, have used bluetoothctl as advised in this posting (and I am using a similar hardware).
To get this working I had modified /etc/triggerhappy/triggers.d/audio.conf and modified all entries from 1 to 0 (zero) - The list of button-names was appropriate but the channel doesn’t fit …
e.g.:
KEY_NEXTSONG 0 /usr/local/bin/volumio next
instead of given entry:
KEY_NEXTSONG 1 /usr/local/bin/volumio next
The one and only “misbehaviour” I have identified so far is a not working reboot.
Could not figure out when and how but sometimes the system does the reboot (in terminal as well as in Volumio GUI) - sometimes not…
Hard to get a logfile for this…
For me this (in real life) doesn’t matter, too - because in “production”
environment a reboot is a seldom event and I do have a smart plug which I can switch off and on remotely …
What I had expected but is not true: I had assumed that startup on a raspi5 with bookwork will be a little bit faster but this is (currently) not the case. May becomes true if installed on NVME - alpha test environment is on SD-card because I do not want to kill my working copy and I’m not able to flash the alpha-image to NVME. (I’m sure this can be performed by a unix guru with magic commands but I’m far away from this and would need the raspi imager or balena etcher do do this for me… )
Thanks again for a great work!
Really impressive!
Warmest regards,
Ralf
