Raspberry Pi4. When I installed new volumio 3 via reflash, It was wonky. After several reinstalls and reflashing with earlier version, I now cannot even find ip, I have tried ssh but I am not learned to even attempt to identify the problem. I have tried cable vs wifi startup and troubleshooted to confirm cabling to pi is good yet no IP address showing on router IP addresses for wire and wireless connections. I have tried IP addresses that list as unknown, but no connection.
The previous version was working and now P! 4 IP completely useless. I have read so many topics, my head is spinning, I have tried many but IT is above my comprehension
try burning with win32diskimager it worked for me on both my pi 4 4gb
if you have a pi 4 2 gb rev 1.5 you need to try a other image that is in test fase.
Thanks. Since I last sent comment, I went to Raspberry pi site for information. I attached monitor and inserted my original SD card with Raspian Pi OS. I then plugged in keyboard and mouse to confirm functionality, All worked fine. i then attached 7" touchscreen with ribbon and 5V power connection.
I reflashed volumio using pi imager. I rebooted now I get “Welcome to Volumio” on toushcscreen with command line access by entering password as shown in Volumio documentation for ssh I get the Volumio logo as shown with command line characters.
How did I get command line access (ssh?) from original boot? I have not done anything since I do not want to create a nightmare.
WEBUI available at volumio.local (192.168.211.1) was shown under “Welcome to Volumio” line.
Euh Volumio is a headless system (no keyboard, no screen, no mouse) So it will boot default to teh shell.
If you want to attach a rPi screen to it you need to install the touch display plugin
The touchscreen might be the cause of poor performances and freezes. I suggest to power the touchscreen separately from the PI (use 2 Power supplies).
Let us know
Before all my problems appeared with earlier version. I had access to Volumio and did the plugin for touchsreen as well as spotify. the spotify plugin did not show up on screen and as I continued to find out why via several reboots etc. I could not even see IP on router both wire and wireless.
Why should it default to shell? and not simply find network as I confirmed when I ran with rasp pi os?
I am confused as well. when I entered the IP on my laptop it does not connect. Bear in mind I am not a serious computer user. When I checked router the IP address is not shown? Am I not understanding something?
Ok, if you connect the screen, does it show an ip at the login shell?
You can also connect to the WL-hotspot, the hotspot will be called something like volumio-xxxxx.
If you connect to that, you can enter volumio.local in your browser. That should reveal the WEBUI.
Finally you can download Advanced IP Scanner and see if Volumio appears on your network, called something like “Volumio” and use that IP
I then entered the volumio for volumio login and then password: volumio to enter the volumio linux with another welcome to Volumio for Raspberry Pi (5.10.90-v71+armv71)
final line is: volumio@volumio:"S
192.168.1.211 is on a different subnet from the PC browser, so you should try to make a wireless connection to a network called “volumio_ABCD”, where the “abcd” part may be different in your case. You can do that from an ipad, iphone or android tablet as well.
Is it because it is not booting up properly via coding? That is why it wanted to try ssh before added keyboard and monitor to Pi. I hade hope when I saw “WEBUI available at volumio.local (192.168.211.1)” but was disappointed when I could not find via the options you listed
