Thank you very very much!
Cheers!
1480x320_Gold.zip (101.1 KB)
Now that’s the one I’ve been looking for.
Wielkie dzięki, Grzesiu!
I got this installed and working about a year ago. Now I am trying to upgrade to the latest Volumio version, but the upgrade is failing because some files got modified. Is there an easy way to upgrade, or do I have to flash the SD card to the current version, and then go over the installation steps again?
peppy doesn’t break the update functionality.
You can try to disable the plugin and try to update again.
If that won’t work, you need to reinstall Volumio.
Attention! Everyone who has installed the new version of peppymeter - please reinstall.
Our super programmer @peppy.player made a new fix, fixed bugs.
Thank you so much @peppy.player for all your hard work!
Here is a fix for 1920x1080 for Yamaha M85 and Pioneer M90 skins:
FIX YamahaM85_PioneerM90.zip (1.1 MB)
Hi Gelo!
Are you talking about the new Kandinsky skins or is there a new plugin version above 1.3?
Best Regards/ C
I’m talking about the new, improved version of peppymeter (Kandinsky) from @peppy.player
Some new skins will not work without installing this version of Peppymeter.
How to install the new version Kandinsky Edition?
Easiest: uninstall peppymeter (peppyscreen saver), reinstall peppymeter (as a plugin). The version will install itself.
hi all, is it possible that after installing PeppyMeter as a plugin I won’t be able to update Volumio anymore ? Yesterdey I’ve installed the plugin and today I’ve tried to apply the latest update 3.538 and I’ve got a message saying that “System Software Integrity checked failed, manually edited files were detected…”
any idea how to solve that ?
Thanks,
Damian
switch off your plugin’s and try again. ![]()
Hello Gelo5 I installed these and the hands move to the right, right? As if it should move upwards ![]()
Which resolution, which skin?
If 1920x1080, bottom-up must work. @peppy.player has released the 3rd Kandinsky fix. Make sure you have the latest (reinstall Peppymeter)
How to reinstall peppymeter?
1.Uninstall peppymeter screensaver
We’re not rebooting
- Connect via Putty with volumio
3.standard password: volumio
standard login: volumio
3.If you have already installed peepymeter as a plugin - you have a folder eg.PeppyMeter. The folder is located at /home/volumio
4.After connecting via Putty, write: cd /home/volumio/PeppyMeter (next press:Enter)
5.Then write: volumio plugin install (next press: Enter)
6.Write Y (next press: Enter)
7.The plugin will install itself
I’m an x86 user and I’m using an old version. It’s impossible for me to update.Thank you for the information. My old files are working fine
Hi, is there anything special required to change font sizes on custom screensavers beyond modifying the font.size. values in the meters.txt file ?
TIA
Damian
for E.g in the Meters.txt
font.size.digi = 95 - counter
font.size.light = 40
font.size.regular = 40
font.size.bold = 50
Hi @Gelo5 , thanks for replying on this.I’ve just realized that I was updating the wrong meters.txt changing the original in the unzipped directory instead of the one placed in “/data/plugins/miscellanea/peppy_screensaver/peppymeter/…” (how embarrasing ! )
thanks anyway, you make me realize my mistake by confirming that changing parameters is the only thing required.
Is the contemporary_advanced plugin still required on Volumio 3.512 or is it already integrated in that version? I am trying to reinstall fresh, but that plugin is not compatible with the latest Volumio release.
no it is not required anymore.
take the one in step 4 (download as plugin)
I’m not sure but it could be that peppymeter has been updated in the meantime, I installed it yesterday and it works just fine.
@michel8166 Thank you!
Copy the unzipped plugin file to /home/volumio with eg filezilla.
Open terminal ssh in Volumio and type cd /home/volumio/peppy_screensaver
volume plugin install
