According the specs, its 800(RGB)×480, WVGA, 134PPI
So set the following:
hdmi_group=2
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
hdmi_drive=2
If it still errors, return the screen and get one from Waveshare.
These are very good LCD’s, with amazing support.
And use these for Peppy:.
https://community.volumio.com/uploads/short-url/c9w82pkxJm0ALaaoO7RgpOmppNJ.zip
https://community.volumio.com/uploads/short-url/ybVuXA4yfbfKcF8MWDDfCwT3gBj.zip
Your model is: AT070TN92 or Model AT070TNA2 ?
Also try to change:
hdmi_group=1
hdmi_mode=4
Edit:
I checked, your monitor without calibration has a resolution
720x576
Edit2:
If I’m right - this file will display correctly.
720x576.zip (502.8 KB)
Load to 1024x600
yes best solution is to buy another good lcd… :blush:
hello Gelo5,
you are correct, 720x576 perform a perfect fullscreen meter for my LCD.
can i have the other graphic for this 720x576 resolution please… :pray:
thank you.
First, try calibrating your monitor to a (normal !!!) resolution of 800x480.
https://forums.raspberrypi.com/viewtopic.php?t=231294
I do not anticipate scaling skins to such an unusual resolution.
hello Gelo_5
it’s work, all is fixed, you’re the best bro…
many thanks…
Small update
Project with PeppyMeter Screensaver Plugin for VOLUMIO v2.9xx and 3.0xx buster - #738 by Gelo5?
Great work … many, many thx … short question: in the last days no screensaver starts anymore from you (Gelo5) … should I install peppy-plugin again? Thx a lot …
Do others start?
Where are you uploading?
What resolution?
Hi … thx for reply …
The original meters starts without any problems (1280x800 and 1920x1080)
“Only” Gelo5 meters don’t start :frowning:
Don’t know why … any idea?
This side … last your small update #738 … great work !
Not from which side, but where in the device?
1920x1080 are checked by me, 1280x800 by @naimnatnod
They must work!
/data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_4 (1920x1080) for 1920x1080
/data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_3 (1280x800) for 1280x800
please excuse … my english …
I copied to
/data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_5 (1920x1080) Gelo5
Can I change the directory name? Or is this fix?
Read the post above. No custom_5 (1920x1080) Gelo5 only in existing folder custom_4 (1920x1080)
OK … thank you so much … my mistake … I have change the directory name … please excuse
Has the issue of indicators not working when listening to Tidal Connect been resolved yet?
Hi Gelo,
Would it be possible to get the two skins BlackBlur and YMX-2000 in 1480x320, they look really great. My new streamer is finally finished.
Did you download the latest file?
No photos yet.
Edit:
Photos uploaded
Replace image Advanced ONLY meters (.jpg and .png)
