Try to add to userconfig.txt
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3 0 0 0
hdmi_drive=2
and reboot
What doesn’t start automatically? Peppymeter or the whole volumio?
Still image too big?
Add one more like this:
sudo nano /etc/ssh/sshd_config
set: PermitRootLogin yes and reboot
userconfig.txt: ONLY this
disable_overscan=1
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
In Peppymeter set: custom_4 (1920x1080)
Is the problem that volumio is to big or peppy meter or both.
And all clear. I was looking for why the skin does not fit the screen - and this is your skin. Ah …
Wheaten
3d
Did you install it as the plugin from posting 7 of this topic?
Yes, I installed from the plugin without issues
Here is my screen, as luck would have it also an advance acoustic :slight_smile:
A really fly setup :slight_smile:
Very cool setup!
Do you run a stand-alone PeppyMeter on the left/right blocks? How do you send the VU Meter signal from the player to the left/right blocks?
Thanks!
@peppy.player
I think the left and right boxes are “Advance Acoustics X-A220EVO
So that’s a big compliment for the build Volumio case :smile:
Oops, the player box really looks very similar to those commercial boxes. Though costs much less I believe :slight_smile:
Actually the PeppyMeter can send a VU Meter signal over a local network using the HTTP protocol. In a fast local network the lag is almost negligible. So, theoretically the same setup could be done using the PeppyMeter as a source on the player box and running stand-alone PeppyMeter application on other boxes. Each box would need a Pi and a local network connection.
Exactly, they are real analogue VU meters. The Amps are two Advance Acoustics X-A220EVO Monoblocks
@Aiello inspired me to make 2 skins (Adv X220Evo and Adv X220)
1920x1080_AdvX220.zip (1.8 MB)
1280x400_Adv_X220.zip (722.3 KB)
eye candy, cool stuff :slight_smile:
the needles are twofold ?
No, this is only photo :joy:
Gelo5 had 2 mutch beer that day :stuck_out_tongue: even his peppy was seeing double.
Are you calling Gelo5 a muts? Or much?
What is “muts”?
giphy (1)
Muts = cap or p^ssy but there are more versions of it … eto ne blef
@Wheaten Dutch for ‘vlamiauw’ gij muts …
Ken der met me kapje niet bij …it is very mug :slight_smile: and not maja de bij zet tafel.
Installed a cooling fan. Description by link:
After installing the startup script, PeppyMater stopped working. Can this be fixed?. Thanks.
Uninstall the script.
Buy it yourself:US $8.61 | Raspberry Pi 4 Pure Copper Heatsink Protective Case Passive Cooling Protective Shell Metal Enclosure for Raspberry Pi 4B Mod
