- Yes, I understand.
I’m just finishing rebuilding it.
I will make the .zip with the images in high resolution.
Nice work! You misspelled ‘right’ by the way.
Hi
I installed PeppyMeter Screensaver in my Pi3B with Volumio V2.9 and connected to my monitor through HDMI. I selected 1920x1080 folder.
However, the graphic cannot be fully displayed. The right and lower sides be cropped.
It look like incorrect resolution. But I had checked the file properties are correct.
The normal payback screen also no problem.
Anybody can hep?
Thanks!
What is the resolution of the monitor? If 1920x1080 and it’s a Chinese monitor, you’ll need to add an entry to userconfig.txt
First try adding:
disable_overscan=1
If it doesn’t help, we’ll add another entry.
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3 0 0 0
hdmi_drive=1
First of all, update Volumio to version 3 (as above).
Thanks Gelo5
My monitor is from ViewSonic which is Taiwan/US brand. The resolution is 1920x1080.
May I know where is the userconfig.txt located?
As I used the V2.9 plugins (GPIO-Buttons, Audiophonics ON/OFF, IR Remote Controller) which are not available on V3, I don’t want to upgrade to V3 at this moment.
I will try your suggestion later today, hope it can help!
Many thanks!
Will try tonight!
Hi Gelo5
It works perfectly after I added the line as you suggested.
disable_overscan=1
Thanks for your help!!
Hi Gelo5
Really?
I just keep monitor below status. I though they are not available.
Make a fresh install on a new SD card and you’ll see
OK, will try later.
Really thanks for your help! ![]()
Plugins in beta state are available Only if you enable plugin test mode in IP/dev
Hi!
Once again, I want to say you (dev/users of the plugin) have done an amazing work!
So many nice skins!
Really, well done!
And once again, a call… Please migrate the plugin to Volumio 3! It would be great to have it provides in the store.
Some tips (non exhaustive)
We can help if needed
Details are: https://developers.volumio.com/
Very wise word what you wrote, but @2aCD…
.its works. thank you. Now can have fixe scrensaver ?
Hi, I can’t find solution of my problem.
Hardware:
Raspberry pi 4b with volumio 3.324
Waveshare 5inch Capacitive Touch Display For Raspberry Pi, 800×480, DSI Interface
Nas Synology with music collection (NFS sharing).
But PeppyMeter don’t show me cover’s.
IMG_20220801_205435|666x500
On all skin? Or on a specific one?
Some skins only have indicators, don’t show the cover
