Hi, would it be possible to have skins from 9 to 12 for 1024x600?
@2aCD
First of all - thank you for the excellent and hard work.
I know you are very busy (TomTom or Garmin), but wouldn’t you be able to implement the following suggestions?:
1 Add an extra layer (for everything). For what? For covering e.g. indicators by glass, CDs, etc.
2 Possibility to download min. 2 photos from music folder: e.g. back.png, cdart.png - many people have a back cover and photo of (CD,Tape,Vinyl).Now we only have the front cover
e.g for KODI
3 Adding the ability to rotate (continuously) the selected png image. For what? To be able to upload a rotating disc etc.
e.g for KODI:
animation effect=“rotate” end=“360” center=“auto” time=“8333” loop=“true” reversible=“false” condition="!Player.Paused">Conditional/animation>
texture background=“true”>$INFO[Player.FolderPath]cdart.png</texture
4 Possibility to set maxwide for artist, title, album etc. (but separately). Now it is maxwide the same for everyone (playinfo.maxwidth).
5 Possibility to download information about artist, album, year, genre from TAG?
6 Ability to rotate the pointers to vertical
Please reply. Even if it’s impossible - it’s the world’s best plugin for visual music playback (and I’ve tested a lot …)
Grzegorz
P.S. This is just the beginning …
@bungie240
I will try to
it’s a complete 4K
Thank you so much Gelo5. I have tested the Sansui and Burmaster since your last post for this resolution and it’s outstanding. I really love the Sansui and probably my favorite. When I have time, I will test the last 3 (violin, teac cassette and klanghalm) and post.
Great work!
Hi rajiv.kumar1984 - have you added the below from Gelo5 to the config.txt file? if not use filezilla and navigate to the ‘boot’ folder at the root of all volumio directories - I’ve done a screengrab of how my config file looks…This may help!?
HDMI drive = 1 No sound VIA HDMI
HDMI drive= 2 sound via hdmi
I think Skinmaster Gelo5 needs your resolution.
@naimnatnod - Thank you for the tests.
I replaced the meter.txt files and loaded them.
Swap for everyone except Burmaster
Super, Super, Super!
Only set a shorter time for image change in the plug. E.g. 15s
got it !
Skins in the single version - TESTER @bungie240
1024x600
These are skins for 1024x600 resolution ONLY
We copy to:
/data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_2 (1024x600)
Great job as always @Gelo5
Hi Gelo5 - Thanks again for the additional work to create skins for my resolution, they seem to be working great, see pics below…
Something like that?
Hello everyone, probably a silly question. Once the plugin is installed, can we delete the peppy_screensaver and peppyalsa directories in /home/volumio?
only the peppy_screensaver. peppyalsa is required
Hello, me again. to what extent can you change the selection PeppyMeter 1920x480? can I just pick some of e.g. (1920x1080) count down?
What is the resolution of your monitor?
