1920x720_TEST.zip (158.3 KB)
1920x720_TEST2.zip (1.5 MB)
1920x720_TEST3.zip (999.8 KB)
1920x720_TEST4.zip (1.1 MB)
Thanks,now it works. Thanks for your help!!!
Hi Gelo,
Can you place them on:
OK, if @Darknes confirms it works.
Order, Mr. General Administrator ![]()
hehe,
just trying to keep it organized, with all those templates of yours ![]()
Hello
I’m sorry that I’m replying so late, but I haven’t had much time lately
Thank you Gelo5, your skins work perfectly ![]()
I have another question, if I create one meters file for all earwigs, will it work?
The question is not relevant
I packed everything into one meters file and it works very nicely. Once I manage all the projects at work, I will try to make my own skins because I see that it is quite an interesting topic
thank you very much for your help
If I may ask, Gelo5, what graphics program do you use to edit skins?
Photoshop
hehe, @Gelo5 has the big bucks, all I have is ‘paint (dot) net’ ![]()
Hehehe, don’t be so modest ![]()
Hello again gentlemen ![]()
If I might beg the favor to ask someone to explain like I am 5 years old, how exactly are the steps to install this and have it work?
I have a waveshare 11.9 inch HDMI display and either Pi 3 or 4 (whichever will be best, I have both)
as well as a variety of DAC HATS.
I tried very hard to follow what I could understand in this thread but my comprehension seems to not be so good as I can not get anything on the screen no matter what I do.
So if anyone could list a step by step of what I should do to install, I would be deeply grateful.
I understand this is asking a lot and apologize in advance.
I have been trying so hard and nothing I am doing seems to be correct.
ANyhow, thank you in advance and if this is not something that can be done, I completely understand.
Hallo, peppymeter work good now i Connect a DAC Board via usb to the raspberry and peppymeter stop working. The DAC is a Kadash tone one.
Which Parameter are wrong
- Download the Raspberry Pi imager
- In OS, select: Media -Volumio
3.Install Volumio on the SD card, after installation, insert it into the raspberry and turn it on - You are connecting to the volumioxxxx wifi network
- A page opens where you configure your volume
- After creating an account on Volumio and logging in, install the touch screen plug-in and enable it in the settings
- Enable the SSH protocol in volumeio (enter the ip/dev number in the browser)
- Turn on the wired network in Volumio and set a static IP address
- download peppymeter, putty and filezilla plugins
- connect via filezilla to volumio by entering the following into the server: sftp://xxx.local ; user volumio ; password: volumio
- copy the unpacked peppymeter folder to the location: home/volumio/peppy_screensaver
- turn on putty, connect to volumio by entering the static IP address, the console opens, login:volumio; password: volumio
13.in the console, enter: cd /home/volumio/peppy_screensaver
and then volumio plugin install - after successful installation to the location data/plugins/miscellanea/peppy_screensaver/peppymeter/custom_1920x480; you copy the skins for your display via filezilla (just don’t delete anything)
I recommend watching the video: https://youtu.be/nlPyn8Gw7yk?si=lfjepw8T1Vv8lsLm
I hope I helped and it will work
Thank you so much for replying @Darknes
I tried this video already but will try it again along with your instructions. The issue is I get no output on my screen. It is on and just black. Hopefully the 20th try is the charm. Fingers crossed! ![]()
Also, quick question but peppymeter is the only actual plugin yes? The other two are PC programs correct? IF not I need to know how to get them.
If you mean that the plug-in works but the indicators do not move, I think it may be a matter of audio output settings
I’m sorry but I don’t understand your question
It is ok, I probably did not explain myself very well. I installed everything but have no output to the screen, only black. I will try everything again and post back. ![]()
Install the Touch Display plug-in.
if you have problems with playback (meters do not move) khadas tone 1 then set mixer type to software.
Hello…
What do you mean by that ?
I haven’t come up with the idea of switching to software yet… worth a try if I run into the problem again. ![]()
