When playing very long files, the progress ring (or is it called time circle?) does not display the correct progressed time, although it appears to play the correct time fraction of the piece when selected. For example, if I select ~75% of the progress ring of a 100 minute piece, the display might read 45 minutes, but the music played sounds like it is at the 75 minute mark. My limited testing indicates correct behavior for pieces less than ~70 minutes.
Version 2.245
