Hi forum,
yesterday I tried to add a Waveshare 7" Display to my existing Volumio installation on a Raspberry 3 with an 16GB SD-Card.
But I run in an error at 70% where installer says at the top “Plugin Successfully Installed” and in the details the in installer stops at “Disabling Kiosk Service”.
After a reboot, the plugin appears in the “Intalled Plugins” Section but it doesn’t work. The Display stays at the console.
Because of the “No space left” Errors I also tried an 64GB SD-Card without luck.
Here is the complete log out of the details section:
[code]Installing Plugin
70%
- Verstecke Details
Downloading plugin at http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/miscellanea/touch_display/touchdisplay.zip
END DOWNLOAD: http://volumio.github.io/volumio-plugins/plugins/volumio/armhf/miscellanea/touch_display/touchdisplay.zip
Creating folder on disk
Unpacking plugin
Checking for duplicate plugin
Copying Plugin into location
Installing dependencies
Raspberry Pi install script
Installing fake packages for kernel, bootloader and pi lib
Selecting previously unselected package libraspberrypi0.
(Reading database … 19642 files and directories currently installed.)
Preparing to unpack libraspberrypi0_0.0.1_all.deb …
Unpacking libraspberrypi0 (0.0.1) …
Setting up libraspberrypi0 (0.0.1) …
Selecting previously unselected package raspberrypi-bootloader.
(Reading database … 19646 files and directories currently installed.)
Preparing to unpack raspberrypi-bootloader_0.0.1_all.deb …
Unpacking raspberrypi-bootloader (0.0.1) …
Setting up raspberrypi-bootloader (0.0.1) …
Selecting previously unselected package raspberrypi-kernel.
(Reading database … 19650 files and directories currently installed.)
Preparing to unpack raspberrypi-kernel_0.0.1_all.deb …
Unpacking raspberrypi-kernel (0.0.1) …
Setting up raspberrypi-kernel (0.0.1) …
Putting on hold packages for kernel, bootloader and pi lib
Installing Chromium Dependencies
Get:1 http://archive.volumio.org jessie InRelease [14.9 kB]
Get:2 http://archive.volumio.org jessie InRelease [22.9 kB]
Get:3 http://archive.volumio.org jessie/main Sources [7759 kB]
Get:4 http://archive.volumio.org jessie/contrib Sources [64.5 kB]
Get:5 http://archive.volumio.org jessie/non-free Sources [113 kB]
Get:6 http://archive.volumio.org jessie/rpi Sources [1132 B]
Get:7 http://archive.volumio.org jessie/main armhf Packages [9537 kB]
Get:8 http://archive.volumio.org jessie/contrib armhf Packages [43.3 kB]
Get:9 http://archive.volumio.org jessie/non-free armhf Packages [84.2 kB]
Get:10 http://archive.volumio.org jessie/rpi armhf Packages [1356 B]
Get:11 http://archive.volumio.org jessie/main Sources [57.1 kB]
Get:12 http://archive.volumio.org jessie/ui Sources [17.4 kB]
Get:13 http://archive.volumio.org jessie/main armhf Packages [171 kB]
Get:14 http://archive.volumio.org jessie/ui armhf Packages [58.9 kB]
Ign http://archive.volumio.org jessie/contrib Translation-en
Ign http://archive.volumio.org jessie/main Translation-en
Ign http://archive.volumio.org jessie/non-free Translation-en
Ign http://archive.volumio.org jessie/rpi Translation-en
Ign http://archive.volumio.org jessie/ui Translation-en
Fetched 17.9 MB in 31s (578 kB/s)
Reading package lists…
Building dependency tree…
Reading state information…
0 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
Installing Graphical environment
The following extra packages will be installed:
bsdmainutils cpp cpp-4.9 giblib1 groff-base keyboard-configuration
libcloog-isl4 libcroco3 libdrm-amdgpu1 libdrm-freedreno1 libdrm-nouveau2
libdrm-radeon1 libdrm2 libegl1-mesa libelf1 libepoxy0 libevdev2 libfontenc1
libgbm1 libgif4 libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libglu1-mesa
libimlib2 libinput-bin libinput10 libisl10 libllvm3.9 libmpc3 libmpfr4
libmtdev1 libobrender29 libobt2 libpangoxft-1.0-0 libpciaccess0 libpipeline1
librsvg2-2 librsvg2-common libstartup-notification0 libtxc-dxtn-s2tc0
libutempter0 libwacom-bin libwacom-common libwacom2 libwayland-client0
libwayland-server0 libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0
libxcb-present0 libxcb-shape0 libxcb-sync1 libxcb-util0 libxcb-xfixes0
libxfont1 libxft2 libxkbfile1 libxmu6 libxmuu1 libxpm4 libxshmfence1 libxt6
libxv1 libxxf86dga1 libxxf86vm1 man-db obconf python-xdg scrot x11-apps
x11-session-utils x11-utils x11-xkb-utils x11-xserver-utils xauth xbitmaps
xfonts-100dpi xfonts-75dpi xfonts-base xfonts-encodings xfonts-scalable
xfonts-utils xkb-data xorg-docs-core xserver-common xserver-xorg
xserver-xorg-core xserver-xorg-input-all xserver-xorg-input-libinput
xserver-xorg-input-wacom xserver-xorg-video-fbturbo xterm
Suggested packages:
wamerican wordlist whois vacation cpp-doc gcc-4.9-locales groff pciutils
librsvg2-bin www-browser menu fonts-dejavu libxml2-dev tint2 openbox-menu
openbox-gnome-session openbox-kde-session mesa-utils nickle cairo-5c xfs
xserver xorg-docs x11-xfs-utils xinput xfonts-cyrillic
The following NEW packages will be installed:
libdrm-radeon1 libegl1-mesa libelf1 libepoxy0 libevdev2 libexif12
libfontenc1 libgbm1 libgif4 libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa
libglu1-mesa libimlib2 libinput-bin libinput10 libisl10 libllvm3.9 libmpc3
libmpfr4 libmtdev1 libobrender29 libobt2 libpangoxft-1.0-0 libpciaccess0
libpipeline1 librsvg2-2 librsvg2-common libstartup-notification0
libtxc-dxtn-s2tc0 libutempter0 libwacom-bin libwacom-common libwacom2
libwayland-client0 libwayland-server0 libxaw7 libxcb-dri2-0 libxcb-dri3-0
libxcb-glx0 libxcb-present0 libxcb-shape0 libxcb-sync1 libxcb-util0
libxcb-xfixes0 libxfont1 libxft2 libxkbfile1 libxmu6 libxmuu1 libxpm4
libxshmfence1 libxt6 libxv1 libxxf86dga1 libxxf86vm1 man-db obconf openbox
python-xdg scrot x11-apps x11-session-utils x11-utils x11-xkb-utils
x11-xserver-utils xauth xbitmaps xfonts-100dpi xfonts-75dpi xfonts-base
xfonts-encodings xfonts-scalable xfonts-utils xinit xkb-data xorg
xorg-docs-core xserver-common xserver-xorg xserver-xorg-core
xserver-xorg-input-all xserver-xorg-input-libinput xserver-xorg-input-wacom
The following packages will be upgraded:
libdrm2
1 upgraded, 97 newly installed, 0 to remove and 23 not upgraded.
Need to get 48.3 MB of archives.
After this operation, 130 MB of additional disk space will be used.
Get:1 http://archive.volumio.org/raspbian/ jessie/main libpipeline1 armhf 1.4.0-1 [24.0 kB]
Get:2 http://archive.volumio.org/raspbian/ jessie/main groff-base armhf 1.22.2-8 [1045 kB]
Get:3 http://archive.volumio.org/raspbian/ jessie/main bsdmainutils armhf 9.0.6 [177 kB]
Get:4 http://archive.volumio.org/debian/ jessie/main man-db armhf 2.7.5-1~bpo8+1 [979 kB]
Get:5 http://archive.volumio.org/raspbian/ jessie/main libgif4 armhf 4.1.6-11+deb8u1 [38.0 kB]
Get:6 http://archive.volumio.org/raspbian/ jessie/main libimlib2 armhf 1.4.6-2+deb8u2 [150 kB]
Get:7 http://archive.volumio.org/raspbian/ jessie/main giblib1 armhf 1.2.4-10 [16.2 kB]
Get:8 http://archive.volumio.org/raspbian/ jessie/main keyboard-configuration all 1.123 [766 kB]
Get:9 http://archive.volumio.org/raspbian/ jessie/main libisl10 armhf 0.12.2-2 [327 kB]
Get:10 http://archive.volumio.org/raspbian/ jessie/main libcloog-isl4 armhf 0.18.2-1 [48.1 kB]
Get:11 http://archive.volumio.org/raspbian/ jessie/main libcroco3 armhf 0.6.8-3 [121 kB]
Get:12 http://archive.volumio.org/debian/ jessie/main libdrm2 armhf 2.4.71-1+rpi1 [32.4 kB]
Get:13 http://archive.volumio.org/debian/ jessie/main libdrm-amdgpu1 armhf 2.4.71-1+rpi1 [24.2 kB]
Get:14 http://archive.volumio.org/debian/ jessie/main libdrm-freedreno1 armhf 2.4.71-1+rpi1 [23.8 kB]
Get:15 http://archive.volumio.org/debian/ jessie/main libdrm-nouveau2 armhf 2.4.71-1+rpi1 [23.9 kB]
Get:16 http://archive.volumio.org/debian/ jessie/main libdrm-radeon1 armhf 2.4.71-1+rpi1 [27.8 kB]
Get:17 http://archive.volumio.org/debian/ jessie/main libwayland-client0 armhf 1.11.0-2 [20.0 kB]
Get:18 http://archive.volumio.org/debian/ jessie/main libwayland-server0 armhf 1.11.0-2 [23.9 kB]
Get:19 http://archive.volumio.org/debian/ jessie/main libgbm1 armhf 13.0.0-1+rpi1 [55.3 kB]
Get:20 http://archive.volumio.org/raspbian/ jessie/main libxcb-dri2-0 armhf 1.10-3 [12.1 kB]
Get:21 http://archive.volumio.org/raspbian/ jessie/main libxcb-dri3-0 armhf 1.10-3 [10.6 kB]
Get:22 http://archive.volumio.org/raspbian/ jessie/main libxcb-present0 armhf 1.10-3 [10.8 kB]
Get:23 http://archive.volumio.org/raspbian/ jessie/main libxcb-shape0 armhf 1.10-3 [11.0 kB]
Get:24 http://archive.volumio.org/raspbian/ jessie/main libxcb-sync1 armhf 1.10-3 [13.2 kB]
Get:25 http://archive.volumio.org/raspbian/ jessie/main libxcb-xfixes0 armhf 1.10-3 [13.8 kB]
Get:26 http://archive.volumio.org/raspbian/ jessie/main libxshmfence1 armhf 1.1-4+rpi1 [6704 B]
Get:27 http://archive.volumio.org/debian/ jessie/main libegl1-mesa armhf 13.0.0-1+rpi1 [97.5 kB]
Get:28 http://archive.volumio.org/raspbian/ jessie/main libelf1 armhf 0.159-4.2 [159 kB]
Get:29 http://archive.volumio.org/raspbian/ jessie/main libevdev2 armhf 1.3+dfsg-1 [22.7 kB]
Get:30 http://archive.volumio.org/raspbian/ jessie/main libexif12 armhf 0.6.21-2 [312 kB]
Get:31 http://archive.volumio.org/raspbian/ jessie/main libfontenc1 armhf 1:1.1.2-1 [23.9 kB]
Get:32 http://archive.volumio.org/debian/ jessie/main libllvm3.9 armhf 1:3.9-4 [9772 kB]
Get:33 http://archive.volumio.org/debian/ jessie/main libgl1-mesa-dri armhf 13.0.0-1+rpi1 [3973 kB]
Get:34 http://archive.volumio.org/debian/ jessie/main libglapi-mesa armhf 13.0.0-1+rpi1 [64.7 kB]
Get:35 http://archive.volumio.org/raspbian/ jessie/main libxcb-glx0 armhf 1.10-3 [23.8 kB]
Get:36 http://archive.volumio.org/raspbian/ jessie/main libxxf86vm1 armhf 1:1.1.3-1 [20.0 kB]
Get:37 http://archive.volumio.org/debian/ jessie/main libgl1-mesa-glx armhf 13.0.0-1+rpi1 [156 kB]
Get:38 http://archive.volumio.org/raspbian/ jessie/main libglu1-mesa armhf 9.0.0-2 [166 kB]
Get:39 http://archive.volumio.org/raspbian/ jessie/main libmpfr4 armhf 3.1.2-2 [501 kB]
Get:40 http://archive.volumio.org/raspbian/ jessie/main libmtdev1 armhf 1.1.5-1 [20.9 kB]
Get:41 http://archive.volumio.org/raspbian/ jessie/main libxft2 armhf 2.3.2-1 [48.3 kB]
Get:42 http://archive.volumio.org/debian/ jessie/ui libpangoxft-1.0-0 armhf 1.36.8-3+rpi1 [193 kB]
Get:43 http://archive.volumio.org/raspbian/ jessie/main libpciaccess0 armhf 0.13.2-3 [44.6 kB]
Get:44 http://archive.volumio.org/raspbian/ jessie/main librsvg2-2 armhf 2.40.5-1+deb8u2 [232 kB]
Get:45 http://archive.volumio.org/raspbian/ jessie/main libxcb-util0 armhf 0.3.8-3 [21.5 kB]
Get:46 http://archive.volumio.org/raspbian/ jessie/main libstartup-notification0 armhf 0.12-4 [19.8 kB]
Get:47 http://archive.volumio.org/raspbian/ jessie/main libxt6 armhf 1:1.1.4-1 [183 kB]
Get:48 http://archive.volumio.org/raspbian/ jessie/main libxmu6 armhf 2:1.1.2-1 [50.8 kB]
Get:49 http://archive.volumio.org/raspbian/ jessie/main libxpm4 armhf 1:3.5.12-0+deb8u1 [43.7 kB]
Get:50 http://archive.volumio.org/raspbian/ jessie/main libxaw7 armhf 2:1.0.12-2 [159 kB]
Get:51 http://archive.volumio.org/raspbian/ jessie/main libxkbfile1 armhf 1:1.0.8-1 [74.9 kB]
Get:52 http://archive.volumio.org/raspbian/ jessie/main libxmuu1 armhf 2:1.1.2-1 [22.8 kB]
Get:53 http://archive.volumio.org/raspbian/ jessie/main libxv1 armhf 2:1.0.10-1+deb8u1 [22.7 kB]
Get:54 http://archive.volumio.org/raspbian/ jessie/main libxxf86dga1 armhf 2:1.1.4-1 [22.4 kB]
Get:55 http://archive.volumio.org/raspbian/ jessie/main libmpc3 armhf 1.0.2-1 [29.7 kB]
Get:56 http://archive.volumio.org/raspbian/ jessie/main libtxc-dxtn-s2tc0 armhf 0~git20131104-1.1 [53.3 kB]
Get:57 http://archive.volumio.org/raspbian/ jessie/main cpp-4.9 armhf 4.9.2-10+deb8u1 [4271 kB]
Get:58 http://archive.volumio.org/raspbian/ jessie/main cpp armhf 4:4.9.2-2 [17.3 kB]
Get:59 http://archive.volumio.org/raspbian/ jessie/main libepoxy0 armhf 1.2-1 [147 kB]
Get:60 http://archive.volumio.org/debian/ jessie/main libwacom-common all 0.22-1 [31.3 kB]
Get:61 http://archive.volumio.org/debian/ jessie/main libwacom2 armhf 0.22-1 [15.5 kB]
Get:62 http://archive.volumio.org/debian/ jessie/main libinput-bin armhf 1.5.0-1 [10.3 kB]
Get:63 http://archive.volumio.org/debian/ jessie/main libinput10 armhf 1.5.0-1 [60.7 kB]
Get:64 http://archive.volumio.org/debian/ jessie/ui libobt2 armhf 3.5.2-8+rpi3 [60.8 kB]
Get:65 http://archive.volumio.org/debian/ jessie/ui libobrender29 armhf 3.5.2-8+rpi3 [69.7 kB]
Get:66 http://archive.volumio.org/raspbian/ jessie/main librsvg2-common armhf 2.40.5-1+deb8u2 [170 kB]
Get:67 http://archive.volumio.org/raspbian/ jessie/main libutempter0 armhf 1.1.5-4 [7516 B]
Get:68 http://archive.volumio.org/debian/ jessie/main libwacom-bin armhf 0.22-1 [5680 B]
Get:69 http://archive.volumio.org/debian/ jessie/main libxfont1 armhf 1:1.5.2-1 [119 kB]
Get:70 http://archive.volumio.org/raspbian/ jessie/main obconf armhf 1:2.0.4-2 [164 kB]
Get:71 http://archive.volumio.org/debian/ jessie/ui openbox armhf 3.5.2-8+rpi3 [277 kB]
Get:72 http://archive.volumio.org/raspbian/ jessie/main python-xdg all 0.25-4 [35.8 kB]
Get:73 http://archive.volumio.org/raspbian/ jessie/main scrot armhf 0.8-13 [18.5 kB]
Get:74 http://archive.volumio.org/raspbian/ jessie/main x11-apps armhf 7.7+4 [529 kB]
Get:75 http://archive.volumio.org/raspbian/ jessie/main x11-session-utils armhf 7.7+1 [60.1 kB]
Get:76 http://archive.volumio.org/raspbian/ jessie/main x11-utils armhf 7.7+2 [172 kB]
Get:77 http://archive.volumio.org/raspbian/ jessie/main x11-xkb-utils armhf 7.7+1 [138 kB]
Get:78 http://archive.volumio.org/raspbian/ jessie/main x11-xserver-utils armhf 7.7+3 [146 kB]
Get:79 http://archive.volumio.org/raspbian/ jessie/main xauth armhf 1:1.0.9-1 [35.6 kB]
Get:80 http://archive.volumio.org/raspbian/ jessie/main xbitmaps all 1.1.1-2 [32.1 kB]
Get:81 http://archive.volumio.org/raspbian/ jessie/main xfonts-encodings all 1:1.0.4-2 [574 kB]
Get:82 http://archive.volumio.org/raspbian/ jessie/main xfonts-utils armhf 1:7.7+2 [68.8 kB]
Get:83 http://archive.volumio.org/raspbian/ jessie/main xfonts-100dpi all 1:1.0.3 [3909 kB]
Get:84 http://archive.volumio.org/raspbian/ jessie/main xfonts-75dpi all 1:1.0.3 [3476 kB]
Get:85 http://archive.volumio.org/raspbian/ jessie/main xfonts-base all 1:1.0.3 [6181 kB]
Get:86 http://archive.volumio.org/raspbian/ jessie/main xfonts-scalable all 1:1.0.3-1 [330 kB]
Get:87 http://archive.volumio.org/raspbian/ jessie/main xinit armhf 1.3.4-1 [46.3 kB]
Get:88 http://archive.volumio.org/raspbian/ jessie/main xkb-data all 2.12-1 [597 kB]
Get:89 http://archive.volumio.org/debian/ jessie/main xserver-common all 2:1.18.4-2+rpi1 [1969 kB]
Get:90 http://archive.volumio.org/debian/ jessie/main xserver-xorg-core armhf 2:1.18.4-2+rpi1 [3031 kB]
Get:91 http://archive.volumio.org/debian/ jessie/main xserver-xorg-video-fbturbo armhf 1.20161111~122359 [23.3 kB]
Get:92 http://archive.volumio.org/debian/ jessie/main xserver-xorg-input-libinput armhf 0.20.0-1 [47.5 kB]
Get:93 http://archive.volumio.org/debian/ jessie/main xserver-xorg-input-all armhf 1:7.7+16 [37.7 kB]
Get:94 http://archive.volumio.org/debian/ jessie/main xserver-xorg-input-wacom armhf 0.33.0-1 [80.7 kB]
Get:95 http://archive.volumio.org/debian/ jessie/main xserver-xorg armhf 1:7.7+16 [93.5 kB]
Get:96 http://archive.volumio.org/raspbian/ jessie/main xorg-docs-core all 1:1.7-1 [82.3 kB]
Get:97 http://archive.volumio.org/raspbian/ jessie/main xterm armhf 312-2 [571 kB]
Get:98 http://archive.volumio.org/raspbian/ jessie/main xorg armhf 1:7.7+7+b1 [37.3 kB]
Fetched 48.3 MB in 28s (1698 kB/s)
Selecting previously unselected package libpipeline1:armhf.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 19654 files and directories currently installed.)
Preparing to unpack …/libpipeline1_1.4.0-1_armhf.deb …
Unpacking libpipeline1:armhf (1.4.0-1) …
Selecting previously unselected package groff-base.
Preparing to unpack …/groff-base_1.22.2-8_armhf.deb …
Unpacking groff-base (1.22.2-8) …
Selecting previously unselected package bsdmainutils.
Preparing to unpack …/bsdmainutils_9.0.6_armhf.deb …
Unpacking bsdmainutils (9.0.6) …
Selecting previously unselected package man-db.
Preparing to unpack …/man-db_2.7.5-1~bpo8+1_armhf.deb …
Unpacking man-db (2.7.5-1~bpo8+1) …
Selecting previously unselected package libgif4:armhf.
Preparing to unpack …/libgif4_4.1.6-11+deb8u1_armhf.deb …
Unpacking libgif4:armhf (4.1.6-11+deb8u1) …
Selecting previously unselected package libimlib2.
Preparing to unpack …/libimlib2_1.4.6-2+deb8u2_armhf.deb …
Unpacking libimlib2 (1.4.6-2+deb8u2) …
Selecting previously unselected package giblib1:armhf.
Preparing to unpack …/giblib1_1.2.4-10_armhf.deb …
Unpacking giblib1:armhf (1.2.4-10) …
Selecting previously unselected package keyboard-configuration.
Preparing to unpack …/keyboard-configuration_1.123_all.deb …
Unpacking keyboard-configuration (1.123) …
Selecting previously unselected package libisl10:armhf.
Preparing to unpack …/libisl10_0.12.2-2_armhf.deb …
Unpacking libisl10:armhf (0.12.2-2) …
Selecting previously unselected package libcloog-isl4:armhf.
Preparing to unpack …/libcloog-isl4_0.18.2-1_armhf.deb …
Unpacking libcloog-isl4:armhf (0.18.2-1) …
Selecting previously unselected package libcroco3:armhf.
Preparing to unpack …/libcroco3_0.6.8-3_armhf.deb …
Unpacking libcroco3:armhf (0.6.8-3) …
Preparing to unpack …/libdrm2_2.4.71-1+rpi1_armhf.deb …
Unpacking libdrm2:armhf (2.4.71-1+rpi1) over (2.4.58-2) …
Selecting previously unselected package libdrm-amdgpu1:armhf.
Preparing to unpack …/libdrm-amdgpu1_2.4.71-1+rpi1_armhf.deb …
Unpacking libdrm-amdgpu1:armhf (2.4.71-1+rpi1) …
Selecting previously unselected package libdrm-freedreno1:armhf.
Preparing to unpack …/libdrm-freedreno1_2.4.71-1+rpi1_armhf.deb …
Unpacking libdrm-freedreno1:armhf (2.4.71-1+rpi1) …
Selecting previously unselected package libdrm-nouveau2:armhf.
Preparing to unpack …/libdrm-nouveau2_2.4.71-1+rpi1_armhf.deb …
Unpacking libdrm-nouveau2:armhf (2.4.71-1+rpi1) …
Selecting previously unselected package libdrm-radeon1:armhf.
Preparing to unpack …/libdrm-radeon1_2.4.71-1+rpi1_armhf.deb …
Unpacking libdrm-radeon1:armhf (2.4.71-1+rpi1) …
Selecting previously unselected package libwayland-client0:armhf.
Preparing to unpack …/libwayland-client0_1.11.0-2_armhf.deb …
Unpacking libwayland-client0:armhf (1.11.0-2) …
Selecting previously unselected package libwayland-server0:armhf.
Preparing to unpack …/libwayland-server0_1.11.0-2_armhf.deb …
Unpacking libwayland-server0:armhf (1.11.0-2) …
Selecting previously unselected package libgbm1:armhf.
Preparing to unpack …/libgbm1_13.0.0-1+rpi1_armhf.deb …
Unpacking libgbm1:armhf (13.0.0-1+rpi1) …
Selecting previously unselected package libxcb-dri2-0:armhf.
Preparing to unpack …/libxcb-dri2-0_1.10-3_armhf.deb …
Unpacking libxcb-dri2-0:armhf (1.10-3) …
Selecting previously unselected package libxcb-dri3-0:armhf.
Preparing to unpack …/libxcb-dri3-0_1.10-3_armhf.deb …
Unpacking libxcb-dri3-0:armhf (1.10-3) …
Selecting previously unselected package libxcb-present0:armhf.
Preparing to unpack …/libxcb-present0_1.10-3_armhf.deb …
Unpacking libxcb-present0:armhf (1.10-3) …
Selecting previously unselected package libxcb-shape0:armhf.
Preparing to unpack …/libxcb-shape0_1.10-3_armhf.deb …
Unpacking libxcb-shape0:armhf (1.10-3) …
Selecting previously unselected package libxcb-sync1:armhf.
Preparing to unpack …/libxcb-sync1_1.10-3_armhf.deb …
Unpacking libxcb-sync1:armhf (1.10-3) …
Selecting previously unselected package libxcb-xfixes0:armhf.
Preparing to unpack …/libxcb-xfixes0_1.10-3_armhf.deb …
Unpacking libxcb-xfixes0:armhf (1.10-3) …
Selecting previously unselected package libxshmfence1:armhf.
Preparing to unpack …/libxshmfence1_1.1-4+rpi1_armhf.deb …
Unpacking libxshmfence1:armhf (1.1-4+rpi1) …
Selecting previously unselected package libegl1-mesa:armhf.
Preparing to unpack …/libegl1-mesa_13.0.0-1+rpi1_armhf.deb …
Unpacking libegl1-mesa:armhf (13.0.0-1+rpi1) …
Selecting previously unselected package libelf1:armhf.
Preparing to unpack …/libelf1_0.159-4.2_armhf.deb …
Unpacking libelf1:armhf (0.159-4.2) …
Selecting previously unselected package libevdev2.
Preparing to unpack …/libevdev2_1.3+dfsg-1_armhf.deb …
Unpacking libevdev2 (1.3+dfsg-1) …
Selecting previously unselected package libexif12:armhf.
Preparing to unpack …/libexif12_0.6.21-2_armhf.deb …
Unpacking libexif12:armhf (0.6.21-2) …
Selecting previously unselected package libfontenc1:armhf.
Preparing to unpack …/libfontenc1_1%3a1.1.2-1_armhf.deb …
Unpacking libfontenc1:armhf (1:1.1.2-1) …
Selecting previously unselected package libllvm3.9:armhf.
Preparing to unpack …/libllvm3.9_1%3a3.9-4_armhf.deb …
Unpacking libllvm3.9:armhf (1:3.9-4) …
dpkg: error processing archive /var/cache/apt/archives/libllvm3.9_1%3a3.9-4_armhf.deb (–unpack):
cannot copy extracted data for ‘./usr/lib/arm-linux-gnueabihf/libLLVM-3.9.so.1’ to ‘/usr/lib/arm-linux-gnueabihf/libLLVM-3.9.so.1.dpkg-new’: failed to write (No space left on device)
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Selecting previously unselected package libgl1-mesa-dri:armhf.
Preparing to unpack …/libgl1-mesa-dri_13.0.0-1+rpi1_armhf.deb …
Unpacking libgl1-mesa-dri:armhf (13.0.0-1+rpi1) …
Selecting previously unselected package libglapi-mesa:armhf.
Preparing to unpack …/libglapi-mesa_13.0.0-1+rpi1_armhf.deb …
Unpacking libglapi-mesa:armhf (13.0.0-1+rpi1) …
Selecting previously unselected package libxcb-glx0:armhf.
Preparing to unpack …/libxcb-glx0_1.10-3_armhf.deb …
Unpacking libxcb-glx0:armhf (1.10-3) …
Selecting previously unselected package libxxf86vm1:armhf.
Preparing to unpack …/libxxf86vm1_1%3a1.1.3-1_armhf.deb …
Unpacking libxxf86vm1:armhf (1:1.1.3-1) …
Selecting previously unselected package libgl1-mesa-glx:armhf.
Preparing to unpack …/libgl1-mesa-glx_13.0.0-1+rpi1_armhf.deb …
Unpacking libgl1-mesa-glx:armhf (13.0.0-1+rpi1) …
Selecting previously unselected package libglu1-mesa:armhf.
Preparing to unpack …/libglu1-mesa_9.0.0-2_armhf.deb …
Unpacking libglu1-mesa:armhf (9.0.0-2) …
Selecting previously unselected package libmpfr4:armhf.
Preparing to unpack …/libmpfr4_3.1.2-2_armhf.deb …
Unpacking libmpfr4:armhf (3.1.2-2) …
Selecting previously unselected package libmtdev1:armhf.
Preparing to unpack …/libmtdev1_1.1.5-1_armhf.deb …
Unpacking libmtdev1:armhf (1.1.5-1) …
Selecting previously unselected package libxft2:armhf.
Preparing to unpack …/libxft2_2.3.2-1_armhf.deb …
Unpacking libxft2:armhf (2.3.2-1) …
Selecting previously unselected package libpangoxft-1.0-0:armhf.
Preparing to unpack …/libpangoxft-1.0-0_1.36.8-3+rpi1_armhf.deb …
Unpacking libpangoxft-1.0-0:armhf (1.36.8-3+rpi1) …
Selecting previously unselected package libpciaccess0:armhf.
Preparing to unpack …/libpciaccess0_0.13.2-3_armhf.deb …
Unpacking libpciaccess0:armhf (0.13.2-3) …
Selecting previously unselected package librsvg2-2:armhf.
Preparing to unpack …/librsvg2-2_2.40.5-1+deb8u2_armhf.deb …
Unpacking librsvg2-2:armhf (2.40.5-1+deb8u2) …
Selecting previously unselected package libxcb-util0:armhf.
Preparing to unpack …/libxcb-util0_0.3.8-3_armhf.deb …
Unpacking libxcb-util0:armhf (0.3.8-3) …
Selecting previously unselected package libstartup-notification0:armhf.
Preparing to unpack …/libstartup-notification0_0.12-4_armhf.deb …
Unpacking libstartup-notification0:armhf (0.12-4) …
Selecting previously unselected package libxt6:armhf.
Preparing to unpack …/libxt6_1%3a1.1.4-1_armhf.deb …
Unpacking libxt6:armhf (1:1.1.4-1) …
Selecting previously unselected package libxmu6:armhf.
Preparing to unpack …/libxmu6_2%3a1.1.2-1_armhf.deb …
Unpacking libxmu6:armhf (2:1.1.2-1) …
Selecting previously unselected package libxpm4:armhf.
Preparing to unpack …/libxpm4_1%3a3.5.12-0+deb8u1_armhf.deb …
Unpacking libxpm4:armhf (1:3.5.12-0+deb8u1) …
Selecting previously unselected package libxaw7:armhf.
Preparing to unpack …/libxaw7_2%3a1.0.12-2_armhf.deb …
Unpacking libxaw7:armhf (2:1.0.12-2) …
Selecting previously unselected package libxkbfile1:armhf.
Preparing to unpack …/libxkbfile1_1%3a1.0.8-1_armhf.deb …
Unpacking libxkbfile1:armhf (1:1.0.8-1) …
Selecting previously unselected package libxmuu1:armhf.
Preparing to unpack …/libxmuu1_2%3a1.1.2-1_armhf.deb …
Unpacking libxmuu1:armhf (2:1.1.2-1) …
Selecting previously unselected package libxv1:armhf.
Preparing to unpack …/libxv1_2%3a1.0.10-1+deb8u1_armhf.deb …
Unpacking libxv1:armhf (2:1.0.10-1+deb8u1) …
Selecting previously unselected package libxxf86dga1:armhf.
Preparing to unpack …/libxxf86dga1_2%3a1.1.4-1_armhf.deb …
Unpacking libxxf86dga1:armhf (2:1.1.4-1) …
Selecting previously unselected package libmpc3:armhf.
Preparing to unpack …/libmpc3_1.0.2-1_armhf.deb …
Unpacking libmpc3:armhf (1.0.2-1) …
Selecting previously unselected package libtxc-dxtn-s2tc0:armhf.
Preparing to unpack …/libtxc-dxtn-s2tc0_0~git20131104-1.1_armhf.deb …
Unpacking libtxc-dxtn-s2tc0:armhf (0~git20131104-1.1) …
Selecting previously unselected package cpp-4.9.
Preparing to unpack …/cpp-4.9_4.9.2-10+deb8u1_armhf.deb …
Unpacking cpp-4.9 (4.9.2-10+deb8u1) …
dpkg: error processing archive /var/cache/apt/archives/cpp-4.9_4.9.2-10+deb8u1_armhf.deb (–unpack):
cannot copy extracted data for ‘./usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1’ to ‘/usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1.dpkg-new’: failed to write (No space left on device)
Selecting previously unselected package cpp.
Preparing to unpack …/cpp_4%3a4.9.2-2_armhf.deb …
Unpacking cpp (4:4.9.2-2) …
Selecting previously unselected package libepoxy0.
Preparing to unpack …/libepoxy0_1.2-1_armhf.deb …
Unpacking libepoxy0 (1.2-1) …
Selecting previously unselected package libwacom-common.
Preparing to unpack …/libwacom-common_0.22-1_all.deb …
Unpacking libwacom-common (0.22-1) …
Selecting previously unselected package libwacom2:armhf.
Preparing to unpack …/libwacom2_0.22-1_armhf.deb …
Unpacking libwacom2:armhf (0.22-1) …
Selecting previously unselected package libinput-bin.
Preparing to unpack …/libinput-bin_1.5.0-1_armhf.deb …
Unpacking libinput-bin (1.5.0-1) …
Selecting previously unselected package libinput10:armhf.
Preparing to unpack …/libinput10_1.5.0-1_armhf.deb …
Unpacking libinput10:armhf (1.5.0-1) …
Selecting previously unselected package libobt2.
Preparing to unpack …/libobt2_3.5.2-8+rpi3_armhf.deb …
Unpacking libobt2 (3.5.2-8+rpi3) …
Selecting previously unselected package libobrender29.
Preparing to unpack …/libobrender29_3.5.2-8+rpi3_armhf.deb …
Unpacking libobrender29 (3.5.2-8+rpi3) …
Selecting previously unselected package librsvg2-common:armhf.
Preparing to unpack …/librsvg2-common_2.40.5-1+deb8u2_armhf.deb …
Unpacking librsvg2-common:armhf (2.40.5-1+deb8u2) …
Selecting previously unselected package libutempter0.
Preparing to unpack …/libutempter0_1.1.5-4_armhf.deb …
Unpacking libutempter0 (1.1.5-4) …
Selecting previously unselected package libwacom-bin.
Preparing to unpack …/libwacom-bin_0.22-1_armhf.deb …
Unpacking libwacom-bin (0.22-1) …
Selecting previously unselected package libxfont1:armhf.
Preparing to unpack …/libxfont1_1%3a1.5.2-1_armhf.deb …
Unpacking libxfont1:armhf (1:1.5.2-1) …
Selecting previously unselected package obconf.
Preparing to unpack …/obconf_1%3a2.0.4-2_armhf.deb …
Unpacking obconf (1:2.0.4-2) …
Selecting previously unselected package openbox.
Preparing to unpack …/openbox_3.5.2-8+rpi3_armhf.deb …
Unpacking openbox (3.5.2-8+rpi3) …
Selecting previously unselected package python-xdg.
Preparing to unpack …/python-xdg_0.25-4_all.deb …
Unpacking python-xdg (0.25-4) …
Selecting previously unselected package scrot.
Preparing to unpack …/scrot_0.8-13_armhf.deb …
Unpacking scrot (0.8-13) …
Selecting previously unselected package x11-apps.
Preparing to unpack …/x11-apps_7.7+4_armhf.deb …
Unpacking x11-apps (7.7+4) …
Selecting previously unselected package x11-session-utils.
Preparing to unpack …/x11-session-utils_7.7+1_armhf.deb …
Unpacking x11-session-utils (7.7+1) …
Selecting previously unselected package x11-utils.
Preparing to unpack …/x11-utils_7.7+2_armhf.deb …
Unpacking x11-utils (7.7+2) …
Selecting previously unselected package x11-xkb-utils.
Preparing to unpack …/x11-xkb-utils_7.7+1_armhf.deb …
Unpacking x11-xkb-utils (7.7+1) …
Selecting previously unselected package x11-xserver-utils.
Preparing to unpack …/x11-xserver-utils_7.7+3_armhf.deb …
Unpacking x11-xserver-utils (7.7+3) …
Selecting previously unselected package xauth.
Preparing to unpack …/xauth_1%3a1.0.9-1_armhf.deb …
Unpacking xauth (1:1.0.9-1) …
Selecting previously unselected package xbitmaps.
Preparing to unpack …/xbitmaps_1.1.1-2_all.deb …
Unpacking xbitmaps (1.1.1-2) …
Selecting previously unselected package xfonts-encodings.
Preparing to unpack …/xfonts-encodings_1%3a1.0.4-2_all.deb …
Unpacking xfonts-encodings (1:1.0.4-2) …
Selecting previously unselected package xfonts-utils.
Preparing to unpack …/xfonts-utils_1%3a7.7+2_armhf.deb …
Unpacking xfonts-utils (1:7.7+2) …
Selecting previously unselected package xfonts-100dpi.
Preparing to unpack …/xfonts-100dpi_1%3a1.0.3_all.deb …
Unpacking xfonts-100dpi (1:1.0.3) …
dpkg: error processing archive /var/cache/apt/archives/xfonts-100dpi_1%3a1.0.3_all.deb (–unpack):
cannot copy extracted data for ‘./usr/share/fonts/X11/100dpi/lubB12.pcf.gz’ to ‘/usr/share/fonts/X11/100dpi/lubB12.pcf.gz.dpkg-new’: failed to write (No space left on device)
warning: /usr/share/fonts/X11/100dpi does not exist or is not a directory
sed: can’t read /var/lib/xfonts/excluded-aliases: No such file or directory
/usr/sbin/update-fonts-alias: 113: /usr/sbin/update-fonts-alias: cannot create /var/lib/xfonts/excluded-aliases: Directory nonexistent
warning: /etc/X11/fonts/100dpi does not exist or is not a directory
Selecting previously unselected package xfonts-75dpi.
Preparing to unpack …/xfonts-75dpi_1%3a1.0.3_all.deb …
Unpacking xfonts-75dpi (1:1.0.3) …
dpkg: error processing archive /var/cache/apt/archives/xfonts-75dpi_1%3a1.0.3_all.deb (–unpack):
cannot copy extracted data for ‘./usr/share/fonts/X11/75dpi/lubBI24.pcf.gz’ to ‘/usr/share/fonts/X11/75dpi/lubBI24.pcf.gz.dpkg-new’: failed to write (No space left on device)
warning: /usr/share/fonts/X11/75dpi does not exist or is not a directory
warning: /etc/X11/fonts/75dpi does not exist or is not a directory
Selecting previously unselected package xfonts-base.
Preparing to unpack …/xfonts-base_1%3a1.0.3_all.deb …
Unpacking xfonts-base (1:1.0.3) …
dpkg: error processing archive /var/cache/apt/archives/xfonts-base_1%3a1.0.3_all.deb (–unpack):
cannot copy extracted data for ‘./usr/share/fonts/X11/misc/clR8x14.pcf.gz’ to ‘/usr/share/fonts/X11/misc/clR8x14.pcf.gz.dpkg-new’: failed to write (No space left on device)
warning: /usr/share/fonts/X11/misc does not exist or is not a directory
warning: /etc/X11/fonts/misc does not exist or is not a directory
Selecting previously unselected package xfonts-scalable.
Preparing to unpack …/xfonts-scalable_1%3a1.0.3-1_all.deb …
Unpacking xfonts-scalable (1:1.0.3-1) …
Selecting previously unselected package xinit.
Preparing to unpack …/xinit_1.3.4-1_armhf.deb …
Unpacking xinit (1.3.4-1) …
Selecting previously unselected package xkb-data.
Preparing to unpack …/xkb-data_2.12-1_all.deb …
Unpacking xkb-data (2.12-1) …
dpkg: error processing archive /var/cache/apt/archives/xkb-data_2.12-1_all.deb (–unpack):
cannot copy extracted data for ‘./usr/share/X11/xkb/symbols/ru’ to ‘/usr/share/X11/xkb/symbols/ru.dpkg-new’: failed to write (No space left on device)
Selecting previously unselected package xserver-common.
Preparing to unpack …/xserver-common_2%3a1.18.4-2+rpi1_all.deb …
Unpacking xserver-common (2:1.18.4-2+rpi1) …
Selecting previously unselected package xserver-xorg-core.
Preparing to unpack …/xserver-xorg-core_2%3a1.18.4-2+rpi1_armhf.deb …
Unpacking xserver-xorg-core (2:1.18.4-2+rpi1) …
dpkg: error processing archive /var/cache/apt/archives/xserver-xorg-core_2%3a1.18.4-2+rpi1_armhf.deb (–unpack):
cannot copy extracted data for ‘./usr/share/doc/xserver-xorg-core/copyright’ to ‘/usr/share/doc/xserver-xorg-core/copyright.dpkg-new’: failed to write (No space left on device)
Selecting previously unselected package xserver-xorg-video-fbturbo.
Preparing to unpack …/xserver-xorg-video-fbturbo_1.20161111~122359_armhf.deb …
Unpacking xserver-xorg-video-fbturbo (1.20161111~122359) …
dpkg: error processing archive /var/cache/apt/archives/xserver-xorg-video-fbturbo_1.20161111~122359_armhf.deb (–unpack):
unable to flush new file ‘/var/lib/dpkg/info/xserver-xorg-video-fbturbo.list-new’: No space left on device
Selecting previously unselected package xserver-xorg-input-libinput.
Preparing to unpack …/xserver-xorg-input-libinput_0.20.0-1_armhf.deb …
Unpacking xserver-xorg-input-libinput (0.20.0-1) …
dpkg: error processing archive /var/cache/apt/archives/xserver-xorg-input-libinput_0.20.0-1_armhf.deb (–unpack):
error creating directory `./usr/lib/xorg/modules/input’: No space left on device
dpkg: unrecoverable fatal error, aborting:
unable to flush /var/lib/dpkg/updates/tmp.i after padding: No space left on device
Installing Chromium
Dependencies installed
Creating Kiosk Data dir
Creating chromium kiosk start script
Creating Systemd Unit for Kiosk
Allowing volumio to start an xsession
Adding plugin to registry
volumio[/code]
I hope someone can help me
