Hello all!
First time user with PiFi Berry DAC running on Pi 3 B.
On the initial boot up with the Pi connected via the LAN-cable to the router i was not able to find the Volumio interface neither by volumio.local nor by direct IP address from my PC browser.
Then i tried accessing the Volumio’s wi-fi hotspot via my phone and it worked. Setup went fine, network settings showed both wifi and cable connections active and ОК.
At this point Volumio interface worked on my phone, but not on the PC. Then i decided to unplug the LAN-cable and try the wireless networking… and It all went down. No access via PC, no access via the phone. Plugged the cable back, tried rebooting - no connection at all from any device.
How do i fix this and if i plan to use Volumio mostly via Wi-Fi, should i plug the LAN-cable at all?
Any alternative ways to connect to Volumio via PC I’m running Win 7, 64-bit and Chrome browser. How do i troubleshoot this?
