Thanks for your reply! Tried usb2 now. DoP works if connected to usb2 and no down sampling with high res flac! Marantz DAC is connected directly to Sparky usb2. The problem is with usb3.
Okay, I think you are wrong. If you have async usb-dac and galvanic isolation (or optical cable), then the electrical noise is almost gone or below -120dB. If you have a bad clock you may have buffer under runs and pops/clicks. USB noise may be coming from bad/cheap smps. Believe me, I’ve seen/measured really bad ones.
Sry about OT, this is not Volumio bug topic anymore. Let’s stick to Sparky USB3 port and Volumio bug.
OK sorry I missed the fact that you have galvanic isolation.
So from what I know…on audio files there should be absolutely no difference on SQ based only on clocks. Bits are bits. On asynchronous data transfer there can be no buffer over/under runs .
However in practice , I do agree that things are not always like theory . I have no doubt that your SQ improves in USB 3.0. However to exactly pinpoint the answer is not an easy task.
