Problems with Album Art alignment in 1366 x 768 resuloution
The are problems with Album Art alignment - this was Okay in version 3.703 but not in version 3.742
My screen resolution is 1366 x 768 and changing this is not really a satisfactory option
I have attached a screenshot showing the problem
As can be seen the albumart overlaps buttons and the progress bar.
The second screen shot shows the correct alignment in version 3.703
Hoping for a solution
Michael
Thanks, we will fix it.
We are finding particularly challenging to have Manifest to be optimized for all screen ratios (some are very peculiar…). These feedbacks are very welcome to get us there!
Thank you for that - I have a attached a short mp4 file showing the difference between versions 3.703 and 3.757
I hope this makes my problem clear
That’s similar to what I have on a second screen (3840 x 2160) with the browser zoom up to 150%. Tabs etc seem fine but could you double check the zoom is on 100%?
Zoom is on 100%
