is there a limitation of the number of tracks managed by Volumio ?
I have a SSD disk connect in USB, with 107 Gbytes of music (16K tracks) and when I boot the Raspi with the disk connected, Volumio doesn’t start;
if I connect the disk after the start of Volumio, I have no problem.
I have tested with just 200 tracks, it’s OK; so it’s not a SSD disk problem.
thanks for your help
Somebody else posted a similar problem to yourself a few days ago, may be worth a quick look about, unfortunately lots of questions go unanswered in these forums, a cpl of mine have never been addressed.
It seems if nobody has a definitive answer then your question is ignored.
I have a very large music library solely in flac up to 192/24 and the larger files are slow to show up artwork etc but they do populate and play etc.
Your exact answer I don’t have I’m afraid.
I hope your question isn’t lost as mine were.
This a little unfair, if there is an obvious answer then that is usually what you are given. If it is a much asked question, then perhaps people should rely on searching. If there is no answer, then perhaps at this point, people do not have an answer
Volumio has a very small team, and relies on the Community to help everyone else out. If you feel that more could be done, then please feel free to contribute.
I would indeed contribute more if I had the knowledge, I know little of Linux programming hence why I am here, and hence why I asked my questions, that went answered, after a search too I might add.
I do however contribute, in the short time I have been here, with greeting new members and trying to help out where I can with my limited knowledge base.
Ps apologies to the OP Didier for this deviation in his thread.
I have PlayerPro and well over 15,000 songs. My problem is getting the artwork and editiding the tag on each one. Any help will will be greatly appreciated.
gcarlile39@gmail.com
gcarlile@cfl.rr…com
Sent from my SM-G965U using Tapatalk
For editing tags and album art have a look at Musicbrainz Picard picard.musicbrainz.org/
Or if you prefer to to work in just a terminal beets.io
Sent from my SM-N950F using Tapatalk
