It is not possible with a new download of 2.917 to use SSH. To fix this you start up with a HDMI monitor connected and after logging in create an empty file called SSH in the /boot directory.
I also cannot get the Nanosound CD plugin to work after installing it. I had it working with the previous version of volumio and it worked after upgrade but I decided to do a clean install and now it doesn’t work. The fault report just shows that the previously selected web radio selected is stopped and nothing else. A lsblk command show that the cd is mounted at sr0
I tried uninstalling and reinstalling the nanosound cd plug in
and I attach the log file which shows some things that look like problems
Nanosound CD Successfully Installed, Do you want to enable the plugin now?
Downloading plugin at http://plugins.volumio.org/plugins/volumio/armhf/music_service/nanosound_cd/nanosound_cd.zip
END DOWNLOAD: http://plugins.volumio.org/plugins/volumio/armhf/music_service/nanosound_cd/nanosound_cd.zip
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Installing nanosound cd Dependencies
NanoSound CD takes around 15 minutes to install. Please be patient.
Hit http://archive.volumio.org jessie InRelease
Hit http://archive.volumio.org jessie/main Sources
Hit http://archive.volumio.org jessie/contrib Sources
Hit http://archive.volumio.org jessie/non-free Sources
Hit http://archive.volumio.org jessie/rpi Sources
Hit http://archive.volumio.org jessie/main armhf Packages
Hit http://archive.volumio.org jessie/contrib armhf Packages
Hit http://archive.volumio.org jessie/non-free armhf Packages
Hit http://archive.volumio.org jessie/rpi armhf Packages
Hit http://archive.volumio.org jessie/ui Sources
Hit http://archive.volumio.org jessie/ui armhf Packages
Ign http://archive.volumio.org jessie/contrib Translation-en
Ign http://archive.volumio.org jessie/main Translation-en
Ign http://archive.volumio.org jessie/non-free Translation-en
Ign http://archive.volumio.org jessie/rpi Translation-en
Ign http://archive.volumio.org jessie/ui Translation-en
Reading package lists…
Installing Flask
Building dependency tree…
Reading state information…
python-dev is already the newest version.
python-pip is already the newest version.
python-setuptools is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 26 not upgraded.
Requirement already up-to-date: pip==20.3.4 in /usr/local/lib/python2.7/dist-packages (20.3.4)
Requirement already satisfied: Flask==1.1.2 in /usr/local/lib/python2.7/dist-packages (1.1.2)
Requirement already satisfied: itsdangerous>=0.24 in /usr/local/lib/python2.7/dist-packages (from Flask==1.1.2) (1.1.0)
Requirement already satisfied: click>=5.1 in /usr/local/lib/python2.7/dist-packages (from Flask==1.1.2) (7.1.2)
Requirement already satisfied: Werkzeug>=0.15 in /usr/local/lib/python2.7/dist-packages (from Flask==1.1.2) (1.0.1)
Requirement already satisfied: Jinja2>=2.10.1 in /usr/local/lib/python2.7/dist-packages (from Flask==1.1.2) (2.11.3)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/local/lib/python2.7/dist-packages (from Jinja2>=2.10.1->Flask==1.1.2) (1.1.1)
Requirement already satisfied: flask_table in /usr/local/lib/python2.7/dist-packages (0.5.0)
Requirement already satisfied: Flask-Babel in /usr/local/lib/python2.7/dist-packages (from flask_table) (2.0.0)
Requirement already satisfied: Flask in /usr/local/lib/python2.7/dist-packages (from flask_table) (1.1.2)
Requirement already satisfied: Jinja2>=2.5 in /usr/local/lib/python2.7/dist-packages (from Flask-Babel->flask_table) (2.11.3)
Requirement already satisfied: Babel>=2.3 in /usr/local/lib/python2.7/dist-packages (from Flask-Babel->flask_table) (2.9.1)
Requirement already satisfied: pytz in /usr/local/lib/python2.7/dist-packages (from Flask-Babel->flask_table) (2021.3)
Requirement already satisfied: itsdangerous>=0.24 in /usr/local/lib/python2.7/dist-packages (from Flask->flask_table) (1.1.0)
Requirement already satisfied: click>=5.1 in /usr/local/lib/python2.7/dist-packages (from Flask->flask_table) (7.1.2)
Requirement already satisfied: Werkzeug>=0.15 in /usr/local/lib/python2.7/dist-packages (from Flask->flask_table) (1.0.1)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/local/lib/python2.7/dist-packages (from Jinja2>=2.5->Flask-Babel->flask_table) (1.1.1)
Requirement already satisfied: flask_cors in /usr/local/lib/python2.7/dist-packages (3.0.10)
Requirement already satisfied: Flask>=0.9 in /usr/local/lib/python2.7/dist-packages (from flask_cors) (1.1.2)
Requirement already satisfied: Six in /usr/lib/python2.7/dist-packages (from flask_cors) (1.8.0)
Requirement already satisfied: itsdangerous>=0.24 in /usr/local/lib/python2.7/dist-packages (from Flask>=0.9->flask_cors) (1.1.0)
Requirement already satisfied: click>=5.1 in /usr/local/lib/python2.7/dist-packages (from Flask>=0.9->flask_cors) (7.1.2)
Requirement already satisfied: Werkzeug>=0.15 in /usr/local/lib/python2.7/dist-packages (from Flask>=0.9->flask_cors) (1.0.1)
Requirement already satisfied: Jinja2>=2.10.1 in /usr/local/lib/python2.7/dist-packages (from Flask>=0.9->flask_cors) (2.11.3)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/local/lib/python2.7/dist-packages (from Jinja2>=2.10.1->Flask>=0.9->flask_cors) (1.1.1)
Installing memcache
memcached is already the newest version.
Requirement already satisfied: pymemcache==3.4.1 in /usr/local/lib/python2.7/dist-packages (3.4.1)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from pymemcache==3.4.1) (1.8.0)
Installing VLC
vlc is already the newest version.
Requirement already satisfied: python-vlc==3.0.11115 in /usr/local/lib/python2.7/dist-packages (3.0.11115)
Installing Audio Libraries
libasound2-plugins is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Configuring NanoSound CD Service to autostart
nanosoundcd_progressweb.service
nanosoundcd_web.service
NanoSound CD installation is completed. Please reboot
Finalizing installation
Hi there, were you able to get the Nanosound plugin work with 2.917? I have the Dac2Pro and the plug in does nothing to me, the amp and dac doesn’t work.
I had problems installing the plug in , I am using a raspberry pi 1 which seems to have problems if the current draw is high. I ended up starting the install and then turning off the gui until the led on the pi stopped flashing. The install was then OK and it works great. I could only get it to work with the recommended cd drive due to the initial start up current surge.
