Has anyone noticed that after using AirPlay, Volumio seems to be stuck, the left green circle still pulsing and the play button inactive.
When I look at the queue I can select a track to play but Volumio does an automatic restart, after which all is fine again and the track starts playing.
I am having the same issue with v 2.457
I started from scratch and re flashed, AirPlay problem solved, new ones appeared!
