each time i try to play a music file (flac) the music stop after few seconds and i don’t find why !!
the timer stop afet 5 seconds but the music stop after 10 or 15 seconds i think
I tried a new instalation of volumio , foobar , etc etc … i 'm lost
Thanks for everyone for youre help if you can (and sorry for my poor english)
1 : UPnp
2 : i see Volumio and Volumio UPnp in the device list (exactly the same problem both)
playback start (i ear sounds) but stop after few seconds
no error messages just no sound and timer stop
3 the same network and subnet for both device
no Vpn et no firewall
4 its the latest version of foobar2000 (2.24) and the latest version of Volumio ( 12-16-2024 but a tried some older version too)
Jan 29 10:51:02 volumio volumio[974]: error: MyVolumio Custom Token format not valid, refreshing it
Jan 29 10:51:03 volumio volumio[974]: info: MyVolumio login type: Token
Jan 29 10:51:07 volumio volumio[974]: info: Updating MyVolumio device info
Jan 29 10:51:07 volumio volumio[974]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Jan 29 10:51:08 volumio volumio[974]: error: Failed to update MyVolumio device: {"message":"DEVICE_NOT_FOUND"}
Jan 29 10:51:11 volumio volumio[974]: info: MYVOLUMIO: Adding device
Jan 29 10:51:11 volumio volumio[974]: info: MYVOLUMIO: Evaluating Server
Jan 29 10:51:11 volumio volumio[974]: info: Setting Geolocation for MyVolumio to eu2
Jan 29 10:51:11 volumio volumio[974]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Jan 29 10:51:12 volumio volumio[974]: error: Failed to add MyVolumio device: {"message":"USER_NOT_FOUND"}
From the logs, it looks like MyVolumio’s authentication token is out of sync, causing issues like:
"MyVolumio Custom Token format not valid, refreshing it"
"USER_NOT_FOUND" and "DEVICE_NOT_FOUND" errors
Fix: Refresh MyVolumio Login
Try these steps to force a re-authentication:
Log Out and Log Back In:
In the Volumio Web UI, go to Settings > MyVolumio
Click Log Out, then log in again.
Manually Reset MyVolumio Services:
Run the following commands in SSH:
volumio service stop myvolumio
volumio service start myvolumio
Check MyVolumio Status:
volumio service myvolumio status
Restart Volumio:
sudo reboot
If the Issue Persists:
Try re-registering your device in the MyVolumio settings.
Hi, I’ve got foobar and had it since the late 90s, best player for my own collection when at the desk with headphones setup.
I’ve never considered trying to use with volumio, what is the benefit in doing this? I use the volumio mobile app or webface to stream my collection. Wouldn’t mind testing it out, do you still have phone control?
I do wish they updated foobar to easily stream or cast music, all the upnp stuff has been a headache from the start with foobar, very manual setup. Even Plexamp etc is much easier.
I use foobar on my local machine and UPnP to the PI with a PI2AES hat. I’m not having issues but have had a similar problem with Foobar in the past. I suspect it’s a buffer issue within Foobar. Are you upsampling at either end?
Do you have any problems using Foobar or Volumio connected directly not using UPnP?
