Hi, I have a Volumio Primo (version 1) and I have a problem using the device as a transport unit, i.e. connected to my CD player which also acts as an external DAC. It is a Yamaha CD-S3000 which features an ESS ES9018 chip and is compatible with files up to 192kHz/24-bit resolution.
I made the connection via SPDIF coaxial cable, but the sound comes out “stuttering”, with continuous small interruptions.
The problem occurs with all file types, but increases with those that have a higher resolution.
By activating audio resampling on the Primo and converting the stream to the lowest possible frequency, i.e. 44 Khz, the problem is greatly reduced, but even so some stuttering still occurs.
This happens both with files stored on hard drives and with streaming apps.
I hypothesize that the problem could be caused by the Volumio clock, is this possible?
Or could it be a compatibility problem between the two devices??
The Yamaha also has an asynchronous USB input, but I cannot use it with the Primo as to work the Yamaha Steinberg ASIO USB Driver must be installed on the source.
Is there any possibility to get around this obstacle via a plugin?
A thousand thanks
Edited by moderator, using google translate
