Problem with UPnP mconnect and Volumio connection
Volumio 4.073
Raspberry Po 4B
When trying to play songs in mconnect (e.g., Tidal) via UPnP and Volumio as the player, a large number of Volumio devices appear to choose from. In versions 3.xxx, there was only one Volumio player to choose from.
Does anyone know how to solve this problem?
Regards
CG
@volumio the same problem in my case. I like using mconnect instead of tidal connect. To have upnp working first I had to logout. It works, sound quality is great, but unstable (f.e. multiple instances) and have a bad feelings about security of enabling UPNP. Should I be afraid of it or its safe to use it in internal lan?
I have the same problem here. Is this an issue with MConnect or Volumio? I will be testing on Moode shortly.
