Problem with skipping next track in Tidal
I have a strange problem with Tidal and Volumio 4. I am running latest Volumio 4 on Raspberry pi 4 with Hifiberry Digi2Pro sound card and almost everything working fine…except one thing…sometimes, without a couse, when i press next to listen to next song from a selected playlist in Tidal, counter stop working and interface is showing that the track is paused, but track is perfectly continue to play…it is only happening when i press next track, if i let it alone and not try to skip track, its working normaly…this is only in Tidal, not in Spotify…in Volumio interface…it doesn’t matter if i’m using app on mobile phone, on web browser on any other pc, even on my touch display connected to my Pi
…can anyone help?
I forgot to mention, i have another Pi4 with Volumio 3 on it with Dac2Pro and everything if working fine in Tidal…no strange behavior, both pi’s are connected on the same network via ethernet cables
i HAVE THIS PROBLEM TOO
Mine does this also, it also really REALLY wants to play the first track in a playlist all the time.
Also cant get it to play the selected track. It will only play a track 4 places later in the list…v annoying.
Contacted support and they suggested resetting to factory settings, so no clue there.
