In version 1.55:
In version 2:
In version 2 starts to scan and lost. This graph shows the network activity. Do not scan the entire contents of the NAS.
Sometimes a web interface fall off during scanning. Or goes into reboot.
In version 1.55:
In version 2:
Interesting, could you please paste the output of
sudo journalctl -f
when the scanning stops?
#follow
FYI, got the same issue. Had the first version of volumio running fine for ages. Tried the V2 and I loose the network when scanning my library.
First, I lost everything (web interface, ssh, ping. Then I opened an ssh connection before scanning and it kept it opened.
Here is the log when it goes berserk :
Sep 06 20:29:51 volumio mpd[13240]: update: added NAS/Musique/Pop/Emilie Simon - The Big Machine -2009-/2. Dreamland - Emilie Simon.mp3
Sep 06 20:31:57 volumio systemd-journal[13722]: Missed 3495 kernel messages
Sep 06 20:31:57 volumio kernel: [<bf2f0090>] (iptable_nat_ipv4_out [iptable_nat]) from [<c04c6da8>] (nf_iterate+0x84/0x94)
Sep 06 20:31:57 volumio kernel: [<c04c6da8>] (nf_iterate) from [<c04c6e2c>] (nf_hook_slow+0x74/0xcc)
Sep 06 20:31:57 volumio kernel: [<c04c6e2c>] (nf_hook_slow) from [<c04d37e4>] (ip_output+0xf8/0x114)
Sep 06 20:31:57 volumio kernel: [<c04d37e4>] (ip_output) from [<c04d2ef8>] (ip_local_out+0x50/0x54)
Sep 06 20:31:57 volumio kernel: [<c04d2ef8>] (ip_local_out) from [<c04d31f4>] (ip_queue_xmit+0x140/0x378)
Sep 06 20:31:57 volumio kernel: [<c04d31f4>] (ip_queue_xmit) from [<c04ea62c>] (tcp_transmit_skb+0x448/0x914)
Sep 06 20:31:57 volumio kernel: [<c04ea62c>] (tcp_transmit_skb) from [<c04ec614>] (tcp_send_ack+0x140/0x184)
Sep 06 20:31:57 volumio kernel: [<c04ec614>] (tcp_send_ack) from [<c04daee4>] (tcp_cleanup_rbuf+0x84/0x154)
Sep 06 20:31:57 volumio kernel: [<c04daee4>] (tcp_cleanup_rbuf) from [<c04db7cc>] (tcp_recvmsg+0x350/0xac0)
Sep 06 20:31:57 volumio kernel: [<c04db7cc>] (tcp_recvmsg) from [<c0505870>] (inet_recvmsg+0x48/0x5c)
Sep 06 20:31:57 volumio kernel: [<c0505870>] (inet_recvmsg) from [<c047958c>] (kernel_recvmsg+0x74/0x8c)
Sep 06 20:31:57 volumio kernel: [<c047958c>] (kernel_recvmsg) from [<bf4182ac>] (cifs_readv_from_socket+0x14c/0x24c [cifs])
Sep 06 20:31:57 volumio kernel: [<bf4182ac>] (cifs_readv_from_socket [cifs]) from [<bf41d050>] (cifs_readpages_read_into_pages+0x1dc/0x2e4 [cifs])
Sep 06 20:31:57 volumio kernel: [<bf41d050>] (cifs_readpages_read_into_pages [cifs]) from [<bf40acdc>] (cifs_readv_receive+0x190/0x210 [cifs])
Sep 06 20:31:57 volumio kernel: [<bf40acdc>] (cifs_readv_receive [cifs]) from [<bf4187bc>] (cifs_demultiplex_thread+0x410/0x7e4 [cifs])
Sep 06 20:31:57 volumio kernel: [<bf4187bc>] (cifs_demultiplex_thread [cifs]) from [<c003d114>] (kthread+0xdc/0xf8)
Sep 06 20:31:57 volumio kernel: [<c003d114>] (kthread) from [<c000f8a8>] (ret_from_fork+0x14/0x2c)
Sep 06 20:31:57 volumio kernel: Mem-Info:
Sep 06 20:31:57 volumio kernel: active_anon:15453 inactive_anon:17422 isolated_anon:0
active_file:38831 inactive_file:39479 isolated_file:0
unevictable:0 dirty:7 writeback:0 unstable:0
slab_reclaimable:4803 slab_unreclaimable:1952
mapped:16309 shmem:3221 pagetables:569 bounce:0
free:250 free_pcp:174 free_cma:9
Sep 06 20:31:57 volumio kernel: Normal free:1000kB min:2808kB low:3508kB high:4212kB active_anon:61812kB inactive_anon:69688kB active_file:155324kB inactive_file:157916kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:507904kB managed:493844kB mlocked:0kB dirty:28kB writeback:0kB mapped:65236kB shmem:12884kB slab_reclaimable:19212kB slab_unreclaimable:7808kB kernel_stack:1136kB pagetables:2276kB unstable:0kB bounce:0kB free_pcp:696kB local_pcp:696kB free_cma:36kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Sep 06 20:31:57 volumio kernel: lowmem_reserve[]: 0 0
Sep 06 20:31:57 volumio kernel: Normal: 146*4kB (UMEC) 28*8kB (M) 12*16kB (UMC) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1000kB
Sep 06 20:31:57 volumio kernel: 82043 total pagecache pages
Sep 06 20:31:57 volumio kernel: 0 pages in swap cache
Sep 06 20:31:57 volumio kernel: Swap cache stats: add 10, delete 10, find 0/0
Sep 06 20:31:57 volumio kernel: Free swap = 524244kB
Sep 06 20:31:57 volumio kernel: Total swap = 524284kB
Sep 06 20:31:57 volumio kernel: 126976 pages RAM
Sep 06 20:31:57 volumio kernel: 0 pages HighMem/MovableOnly
Sep 06 20:31:57 volumio kernel: 3515 pages reserved
Sep 06 20:31:57 volumio kernel: 2048 pages cma reserved
Sep 06 20:31:57 volumio kernel: smsc95xx 1-1.1:1.0 eth0: kevent 2 may have been dropped
Sep 06 20:31:57 volumio kernel: cifsd: page allocation failure: order:0, mode:0x2080020
Sep 06 20:31:57 volumio kernel: CPU: 0 PID: 816 Comm: cifsd Not tainted 4.4.9+ #884
Sep 06 20:31:57 volumio kernel: Hardware name: BCM2708
Sep 06 20:31:57 volumio kernel: [<c0016c9c>] (unwind_backtrace) from [<c0013c20>] (show_stack+0x20/0x24)
Sep 06 20:31:57 volumio kernel: [<c0013c20>] (show_stack) from [<c02e319c>] (dump_stack+0x20/0x28)
Sep 06 20:31:57 volumio kernel: [<c02e319c>] (dump_stack) from [<c00de5bc>] (warn_alloc_failed+0xe4/0x130)
Sep 06 20:31:57 volumio kernel: [<c00de5bc>] (warn_alloc_failed) from [<c00e1aa0>] (__alloc_pages_nodemask+0x8a8/0xa8c)
Sep 06 20:31:57 volumio kernel: [<c00e1aa0>] (__alloc_pages_nodemask) from [<c00e1eac>] (__alloc_page_frag+0x160/0x190)
Sep 06 20:31:57 volumio kernel: [<c00e1eac>] (__alloc_page_frag) from [<c04870d8>] (__netdev_alloc_skb+0xa4/0x14c)
Sep 06 20:31:57 volumio kernel: [<c04870d8>] (__netdev_alloc_skb) from [<c03c630c>] (rx_submit+0x3c/0x240)
Sep 06 20:31:57 volumio kernel: [<c03c630c>] (rx_submit) from [<c03c69d8>] (rx_complete+0x1f8/0x21c)
Sep 06 20:31:57 volumio kernel: [<c03c69d8>] (rx_complete) from [<c03d07a4>] (__usb_hcd_giveback_urb+0x80/0x160)
Sep 06 20:31:57 volumio kernel: [<c03d07a4>] (__usb_hcd_giveback_urb) from [<c03d08cc>] (usb_hcd_giveback_urb+0x48/0x10c)
Sep 06 20:31:57 volumio kernel: [<c03d08cc>] (usb_hcd_giveback_urb) from [<c03f9e6c>] (completion_tasklet_func+0x6c/0x98)
Sep 06 20:31:57 volumio kernel: [<c03f9e6c>] (completion_tasklet_func) from [<c04089dc>] (tasklet_callback+0x20/0x24)
Sep 06 20:31:57 volumio kernel: [<c04089dc>] (tasklet_callback) from [<c0025c40>] (tasklet_hi_action+0x84/0xd8)
Sep 06 20:31:57 volumio kernel: [<c0025c40>] (tasklet_hi_action) from [<c00252d8>] (__do_softirq+0x124/0x314)
Sep 06 20:31:57 volumio kernel: [<c00252d8>] (__do_softirq) from [<c002581c>] (irq_exit+0xbc/0x11c)
Sep 06 20:31:57 volumio kernel: [<c002581c>] (irq_exit) from [<c005a360>] (__handle_domain_irq+0x60/0xb8)
Sep 06 20:31:57 volumio kernel: [<c005a360>] (__handle_domain_irq) from [<c0010748>] (handle_IRQ+0x2c/0x30)
Sep 06 20:31:57 volumio kernel: [<c0010748>] (handle_IRQ) from [<c000940c>] (bcm2835_handle_irq+0x3c/0x58)
Sep 06 20:31:57 volumio kernel: [<c000940c>] (bcm2835_handle_irq) from [<c0572184>] (__irq_svc+0x44/0x5c)
Sep 06 20:31:57 volumio kernel: Exception stack(0xd7307b28 to 0xd7307b70)
Sep 06 20:31:57 volumio kernel: 7b20: deae70f8 d5560600 0000018e bf2f0024 00000000 deae70f8
Sep 06 20:31:57 volumio kernel: 7b40: d5560600 d7307c34 00000004 bf2f0024 00000000 d7307b84 d7307b88 d7307b78
Sep 06 20:31:57 volumio kernel: 7b60: bf2df684 bf2d52c0 40000013 ffffffff
Sep 06 20:31:57 volumio kernel: [<c0572184>] (__irq_svc) from [<bf2d52c0>] (nf_ct_nat_ext_add+0xc/0x68 [nf_nat])
Sep 06 20:31:57 volumio kernel: [<bf2d52c0>] (nf_ct_nat_ext_add [nf_nat]) from [<bf2df684>] (nf_nat_ipv4_fn+0x58/0x180 [nf_nat_ipv4])
Sep 06 20:31:57 volumio kernel: [<bf2df684>] (nf_nat_ipv4_fn [nf_nat_ipv4]) from [<bf2df87c>] (nf_nat_ipv4_out+0x50/0x114 [nf_nat_ipv4])
Sep 06 20:31:57 volumio kernel: [<bf2df87c>] (nf_nat_ipv4_out [nf_nat_ipv4]) from [<bf2f0090>] (iptable_nat_ipv4_out+0x1c/0x24 [iptable_nat])
It goes into a loop like that for lines and lines and then went back to normal :
Sep 06 20:32:00 volumio kernel: smsc95xx 1-1.1:1.0 eth0: kevent 2 may have been dropped
Sep 06 20:32:00 volumio systemd[1]: Starting Journal Service...
Sep 06 20:31:54 volumio systemd[1]: systemd-journald.service watchdog timeout (limit 1min)!
Sep 06 20:32:00 volumio systemd-journal[13722]: Journal stopped
Sep 06 20:32:00 volumio systemd-journal[13923]: Runtime journal is using 12.0M (max allowed 30.0M, trying to leave 36.1M free of 228.5M available → current limit 30.0M).
Sep 06 20:32:00 volumio systemd-journald[13722]: Received SIGTERM from PID 1 (systemd).
Sep 06 20:32:00 volumio systemd[1]: Unit systemd-journald.service entered failed state.
Sep 06 20:32:00 volumio systemd[1]: systemd-journald.service has no holdoff time, scheduling restart.
Sep 06 20:32:00 volumio systemd[1]: Stopping Journal Service...
Sep 06 20:32:00 volumio systemd[1]: Started Journal Service.
Sep 06 20:32:00 volumio systemd-journal[13923]: Journal started
Sep 06 20:32:00 volumio systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Sep 06 20:32:00 volumio systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Sep 06 20:32:01 volumio systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Sep 06 20:32:01 volumio systemd[1]: Unit volumio.service entered failed state.
Sep 06 20:32:01 volumio systemd[1]: volumio.service holdoff time over, scheduling restart.
Sep 06 20:32:01 volumio systemd[1]: Stopping volumio.service...
Sep 06 20:32:01 volumio systemd[1]: Starting volumio.service...
Sep 06 20:32:01 volumio systemd[1]: Started volumio.service.
Sep 06 20:32:01 volumio kernel: CIFS VFS: Server 192.168.0.45 has not responded in 120 seconds. Reconnecting...
Sep 06 20:32:01 volumio mpd[13240]: client: [2] closed
Sep 06 20:32:01 volumio mpd[13240]: client: [0] closed
Sep 06 20:32:02 volumio mpd[13240]: update: added NAS/Musique/Pop/Sarah Blasko - As Day Follows Night (MP3)/11 I Never Knew.mp3
It did it multiple times during the scan (still going) :
Sep 06 20:39:02 volumio kernel: SLUB: Unable to allocate memory on node -1 (gfp=0x2080020)
Sep 06 20:39:02 volumio kernel: cache: kmalloc-192, object size: 192, buffer size: 192, default order: 0, min order: 0
Sep 06 20:39:02 volumio kernel: node 0: slabs: 37, objs: 777, free: 0
Sep 06 20:39:02 volumio kernel: smsc95xx 1-1.1:1.0 eth0: kevent 2 may have been dropped
Sep 06 20:39:02 volumio kernel: CIFS VFS: Server 192.168.0.45 has not responded in 120 seconds. Reconnecting...
Sep 06 20:39:02 volumio systemd[1]: Starting Journal Service...
Sep 06 20:38:56 volumio mpd[13240]: client: [4] closed
Sep 06 20:38:56 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/11 - La gomme.mp3
Sep 06 20:38:57 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/09 - Les rigueurs de l'hiver.mp3
Sep 06 20:38:57 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/01 - Introduction.mp3
Sep 06 20:38:58 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/14 - Coquilles.mp3
Sep 06 20:38:59 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/16 - Les aventures du mois de juin (2).mp3
Sep 06 20:38:59 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/05 - Coco bello.mp3
Sep 06 20:39:00 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/10 - Perverse mamie.mp3
Sep 06 20:39:00 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/04 - Pub.mp3
Sep 06 20:39:01 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/15 - Les aventures du mois de juin (1).mp3
Sep 06 20:39:01 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/06 - Les cèdres.mp3
Sep 06 20:39:02 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/07 - Aurore.mp3
Sep 06 20:38:56 volumio systemd[1]: systemd-journald.service watchdog timeout (limit 1min)!
Sep 06 20:39:02 volumio systemd-journal[13923]: Journal stopped
Sep 06 20:39:03 volumio systemd-journal[14685]: Runtime journal is using 20.0M (max allowed 30.0M, trying to leave 36.1M free of 220.5M available → current limit 30.0M).
Sep 06 20:39:04 volumio systemd-journald[13923]: Received SIGTERM from PID 1 (systemd).
Sep 06 20:39:04 volumio systemd[1]: Unit systemd-journald.service entered failed state.
Sep 06 20:39:04 volumio systemd[1]: systemd-journald.service has no holdoff time, scheduling restart.
Sep 06 20:39:04 volumio systemd[1]: Stopping Journal Service...
Sep 06 20:39:04 volumio systemd[1]: Starting Journal Service...
Sep 06 20:39:04 volumio systemd[1]: Started Journal Service.
Sep 06 20:39:04 volumio systemd-journal[14685]: Journal started
Sep 06 20:39:02 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/03 - Les 7 erreurs.mp3
Sep 06 20:39:03 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 4/18 - La Marseillaise.mp3
Sep 06 20:39:03 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/20 - Conclusion.mp3
Sep 06 20:39:03 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/05 - Dieu n'est pas bien.mp3
Sep 06 20:39:03 volumio systemd[1]: Starting Trigger Flushing of Journal to Persistent Storage...
Sep 06 20:39:04 volumio systemd[1]: Started Trigger Flushing of Journal to Persistent Storage.
Sep 06 20:39:04 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/04 - Monégascons.mp3
Sep 06 20:39:04 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/14 - Les trois draps du prince d'orient.mp3
Sep 06 20:39:05 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/07 - Bestiaire.mp3
Sep 06 20:39:05 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/18 - Le printemps.mp3
Sep 06 20:39:05 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/01 - Introduction.mp3
Sep 06 20:39:06 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/03 - La rumeur.mp3
Sep 06 20:39:06 volumio mpd[13240]: update: added NAS/Musique/Docs/Pierre Desproges - Les chroniques de la haine ordinaire (1986)/Chroniques de la haine ordinaire - Vol. 3/16 - Misères.mp3
Sep 06 20:39:06 volumio mpd[13240]: client: [6] opened from ::ffff:127.0.0.1:34608
FYI, this is a Rpi B+ with 2A power supply. The I2S Dac has not been activated yet in Volumio V2 but was fin in the V1.
Connection through the library is via samba.
NAS is a Proliant Gen8 with gigabit connection.
Library is about 18 000 files.
The scan did end OK this time. I’m setting up the I2S Dac and rebooting. We’ll see
Thanks again for this software, I did enjoy very much the 1.5 version so far
