Prerequisites
Volumio Information
Volumio Version: 2.806
Hardware: RPi4
DAC: @Marantz SACD-Player SA8005 with CS4398
Debug Log
Sep 09 19:48 : exception: No such playlist
Sep 09 19:48 : exception: Failed to open “alsa” [alsa]
Sep 09 19:48 : exception: nested: Error opening ALSA device “hw:5,0”
Sep 09 19:48 : exception: snd_pcm_hw_params() failed: No such device or address
Sep 09 19:48 : player: problems opening audio device while playing “http://stream.lokalradio.nrw/444zbpy”
Sep 09 19:48 : player: played “http://stream.lokalradio.nrw/444zbpy”
Sep 09 20:02 : player: played “http://stream.lokalradio.nrw/444zbpy”
Sep 09 20:02 : exception: No such playlist
Sep 09 20:02 : exception: Failed to open “alsa” [alsa]
Sep 09 20:02 : exception: nested: Error opening ALSA device “hw:5,0”
Sep 09 20:02 : exception: snd_pcm_hw_params() failed: No such device or address
Sep 09 20:02 : player: problems opening audio device while playing “http://addrad.io/4WRDtQ”
Sep 09 20:02 : player: played “http://addrad.io/4WRDtQ”
Sep 09 20:03 : player: played “http://addrad.io/4WRDtQ”
Steps to Reproduce
- start up or reboot and while trying to play any source first time (1st click),
or an Internet-Radio station it comes following error message:
Fail to open “alsa” [alsa]; Error opening ALSA device “hw:5,0”; snd_pcm_hw_params() failed: No such device or address
- if I try to play the same source for a second time (2nd click) it works.
- This issue can be repeated any time, when the sampling rate of the source changes.
If the source has the same sampling rate, it starts playing without any error message.
Additional Information
SA8005 is correctly recognized as an USB output.Is there a solution for the problem?
Regards,
Adam
