Hello Everybody!
I use Volumio for 2 months without problem.
I listen a lot of internet radio especially Ibiza Global radio.
Since last week i can’t listen this radio because everytime Volumio give me this error:
Failed to decode https://listenssl.ibizaglobalradio.com:8024/stream; CURL failed: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
If i try to connect on my browser on my pc on
all it’s OK and the certificate it’s not expired
How can i fix this problem?
thank you!!
Volumio Information
Volumio Version: 2.873
Hardware: Raspberry pi3 model b
DAC:pirate audio
Despite your browser saying the certificate is OK, there is still some problem at the radio stream’s server. This can be caused by the server not sending the entire certificate chain. Modern browsers often cope with this by rebuilding this chain. Unfortunately openssl (which curl uses) will refuse or is incapable of mimicking the browsers’ actions. You can have a read about such problems here if you are interested. The solution in that link (at the end of the article) doesn’t work in this case, so there is some further complication involved here.
I can only suggest that you contact the radio stream site, and let them know that their servers are not configured properly. Unfortunately, I doubt that they will be interested given that it works OK in a browser.
Thank you for you answer!
i resolve in my way:
erase the station suggest from volumio and insert in my list of internet radio without the https. i use http and finally i can listen the radio station
Yes of course. I got so wrapped up in the ssl problems, that I totally forgot the obvious
