problem with installation on raspi2
i have: raspberry pi2, hifiberry dac+
i tried to install ver.1.55 - but the install progress showed a “fail” and stopped at a certain point - see pics
i tried with different sd-cards - same result
what’s the problem?
please help me
thnx a lot
chris
– at 2 different trials to install, there are 2 different wordings at the end - see pics
Hi! I think everything is OK… At this point have you try to connect to your Volumio from a other device with a web browser? Http:/volumio.Local or IP address from android. Remember that Volumio comes with no graphical interface. You have to access thought the network.
Thank you - you helped me
bye
