I’d like to install Volumio on a my PC but I have difficult to perform the boot using the image downloaded from Volumio website. I tried to flash it using Balena Etcher but the PC doesn’t see the usb key as bootable. Furthermore I tried also to mount directly the .img file on Win10 thinking to boot it via Virtualbox but Windows says me that The image file is corrupted, I’ve also tried to download it again with the same result.
booting from usb is set in the bios boot options… and pick boot from usb stick.
mounting doesn’t work because it schould boot from the stick and img is not corrupt
Yes to all, flashed by balena etcher and tried also another usb stick. The curious thing is that if I try to mount the .img on Win10 the system says that the file is damaged.
it doesn’t work with a mount the img got 3 partitions instead of a normal img of 1 partition…
1 boot fat32 and 2 ext4 and the ext4 is not used on windows.
does your usb stick got recognised in your bios? normaly it should show up.
but there are still some systems that doesn’t support that option…
switching port some times could help.
Nothing to do , I have formatted the local hdd (a disk m.2 500GB) using Fat32 file system using an Ubuntu Boot Live but when try to install on the disk I have the error: Installation on the disk failed: Cannot prepare system for resize.
Have I to abbandon the idea to use Volumio on the pc?
I understand the problem, Volumio is not compatible with m.2 disk, during the week I’ll try with a hdd sata. For now thanks to all, I’ll keep you informed.
Just take the latest Volumio 3 beta for x86, it will also boot from nvme (m2) and the install to disk (incl. emmc, ssd, nvme, hdd) is a lot, lot faster and without errors.
Functionality is nearly as good as Volumio 2, just some cosmetic differences left to iron out.
