Volumio Information
Volumio Version:2.861
Hardware: Raspi 3B+
DAC:
Hi community,
I want to install the snapcast plugin (Version 2.4.3), but i get some errors.
I don’t know, if it is my mistake or if it a problem of the installation procedure.
Installation-log:
Downloading plugin at http://plugins.volumio.org/plugins/volumio/armhf/miscellanea/snapcast/snapcast.zip
END DOWNLOAD: http://plugins.volumio.org/plugins/volumio/armhf/miscellanea/snapcast/snapcast.zip
Erstelle Installationspfad
Plugin wird entpackt
Prüfe, ob Plugin bereits existiert
Kopiere Plugin in sein Verzeichnis
Installiere benötigte Komponenten
Installing SnapCast and its dependencies…
Reading package lists…
Detecting cpu
cpu: armv7l
Selecting previously unselected package snapclient.
(Reading database … 24906 files and directories currently installed.)
Preparing to unpack …/snapclient_0.22.0-1_armhf.deb …
Unpacking snapclient (0.22.0-1) …
Processing triggers for systemd (215-17+deb8u8) …
Selecting previously unselected package snapserver.
(Reading database … 24915 files and directories currently installed.)
Preparing to unpack …/snapserver_0.22.0-1_armhf.deb …
Unpacking snapserver (0.22.0-1) …
Building dependency tree…
Reading state information…
Correcting dependencies… Done
The following package was automatically installed and is no longer required:
libatomic1
Use ‘apt-get autoremove’ to remove it.
The following packages will be REMOVED:
snapclient snapserver
0 upgraded, 0 newly installed, 2 to remove and 24 not upgraded.
2 not fully installed or removed.
After this operation, 4947 kB disk space will be freed.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 24942 files and directories currently installed.)
Removing snapclient (0.22.0-1) …
Removing snapserver (0.22.0-1) …
Installation wird abgeschlossen
The script says, the installation was successful and asks me to activate snapcast.
The message:
Startup failed
Could not start the SnapCast plugin in a fashionable manner.
Restart failed
Restarting snapserver failed with error: Error: Command failed: /usr/bin/sudo /bin/systemctl restart snapserver Failed to restart snapserver.service: Unit snapserver.service is masked.
Thank you
Bernd
